Author Topic: Key fob stopped working help!  (Read 1756 times)
Offline killakam78
  • Don't say i didn't warn you!
« on: 07 December 2010, 16:39 »
Hi Guys
i just fitted a new head unit in my MK4 and for some reason now the fob wont work, i have tested the batteries in fob and they are fine........anybody had this problem? i can use the key to lock it but the locks keep freezing in this weather which is great fun!  :cry:
Offline Rhyso
Re: Key fob stopped working help!
« Reply #1 on: 08 December 2010, 10:51 »
do your interior lights come on when you open the door? Do you electric windows work?
Quite possible you've blown Fuse 14 and it needs replacing
Offline killakam78
« Reply #2 on: 08 December 2010, 13:00 »
Yeah it does, i will check the fuses
Offline Rhyso
« Reply #3 on: 08 December 2010, 13:16 »
So the windows and lights work ok?
Then its not the fuse I've suggested; sorry
Offline killakam78
« Reply #4 on: 08 December 2010, 13:24 »
 :laugh: just went out and checked them aswell! just seems a bit odd that when i went out to wire in the the head unit it was fine, the wiring for the stereo should not have an effect on the fob should it? as i say it works fine off the key
Offline Rhyso
« Reply #5 on: 08 December 2010, 13:27 »
I've heard of instances where this has happened but I can't remember the solution  :undecided:
It will obviously work using just the key.  What I was asking is if the lights and electric windows still work as normal.  If they don't then its deffo the fuse.  If they do work then its something else
Offline Rhyso
« Reply #6 on: 08 December 2010, 14:16 »
This thread may help identify your problem
http://uk-mkivs.net/forums/t/177496.aspx
 :smiley:
Offline killakam78
« Reply #7 on: 08 December 2010, 14:44 »
Cheets will have a look at the thread, as per having the stereo on a permanent live, i wouldnt have thought that would bare any significance to the key unless there is some kinda module behind the stereo which i could have knocked or something, i will have a look at the thread and see if i can brave the cold to have a look! I lovr my golf but its just to cold to be outside lol
Offline Rhyso
« Reply #8 on: 08 December 2010, 14:47 »
An old thread but might help some more
http://uk-mkivs.net/forums/p/122445/827988.aspx#827988
Sounds like something is connected to the K Line (diagnostics line) hence why your remote has stopped working
