Author Topic: Would a cable throttled 1.8 turbo have cruise control - would it work?  (Read 6033 times)
Offline benday007
Hi guys
May seem a silly question but the golf has a cruise control stalk but cruise control does not operate, is it meant to have this stalk or has someone attempted to fit cruise control to a car which won't accommodate the facility??
Cheers!!!!
Offline mcgee9t2
should work. seem to remember they have to be activated though? so has yours been activated/ ever worked?
Offline houston
they dont work on cable, its more likely someones just fitted the stalk, mines the same :sad:
unless you find out otherwise cos id love to get it working on mine.
also needs more than just the stalk fitted
http://www.foxytech.hostcell.net/wiring_-_outside.htm
Offline topher
  • Administrator
  • fully functioning
my old AGU had factory fitted cruise control, it cant be retro-fitted simply though.. bits of loom and ecu need changing.
Offline tech1889
  • Mk2 GTI FTW !!
is it easy job on electric throttle ??
Offline topher
  • Administrator
  • fully functioning
If you're familiar with dismantling the fusebox, steering wheel and wiper motor then yeah, p!ss easy. Plenty of guides around for it :cool:
Offline tech1889
  • Mk2 GTI FTW !!
yer im not that familiar with doing them things.. how much people normally charge ??
Offline topher
  • Administrator
  • fully functioning
150 fitted is about the going rate. Takes me just over an hour. I reckon you'd still manage it in an afternoon, dont be a wuss give it a go :grin:
Offline tech1889
  • Mk2 GTI FTW !!
yer yer will do when money eases up a bit in the new year.. got any secrets places to buy the kit cheap ??
Offline brianpologti
Yep and still going strong
