Author Topic: Golf Mk2 to Mk4 rear caliper conversion  (Read 14043 times)
Re: Golf Mk2 to Mk4 rear caliper conversion
« Reply #10 on: 07 December 2010, 09:21 »
doesnt matter what year mk2 you have, you always keep the std cables. pre-88 mk2s used different shape calipers which means you have to mount MK3/4 calipers upside down, or modify the cable routing. you can swap to later spec cables as they'll be way too short, the difference is down to the style of the handbrake lever not so much the way the calipers are mounted to the beam.
as above need conversion hoses to fit MK4 units, later mk3 units have the same design of handbrake mech so dont sieze as much as mk2, but are a direct swap onto your car. basically look for a handbrake spring, if it has one its a mk2 caliper, if not its later mk3
Offline Ben Lessani
« Reply #11 on: 07 December 2010, 13:18 »
A little of this http://www.golfgtiforum.co.uk/index.php?topic=49436.msg979860#msg979860
Then after, some of this http://www.golfgtiforum.co.uk/index.php?topic=49436.msg1000233#msg1000233
do not use a g-clamp in place of a proper piston winding tool!
Offline Mr Blue
« Reply #12 on: 09 December 2010, 12:34 »
Not only an MOT fail but trying to control a dodgy revving mk2 in uphill traffic can be a handful.
Holding the revs high enough to not stall and reach for the foot brake. Sod that!
Ive converted to the mk4 setup. You just need the banjo brake lines.
Working handbrakes = win
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 11 December 2010, 20:41 »
For More Info Click To See;
Offline Ben Lessani
« Reply #14 on: 11 December 2010, 22:39 »
is it normal practice to loctite the carrier bolts?
I've never used loctite on a car, just torqued to the correct figure.
Offline Mr Blue
« Reply #15 on: 12 December 2010, 13:40 »
Ive started to use loctite on bolts and screws.
We build road side equipment at work. bolts work loose with vibrations if no loctite is used.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #16 on: 12 December 2010, 14:13 »
i quite like loctite especially on bolts i know im not going to take off again for a while..
Offline WYATT
« Reply #17 on: 07 January 2011, 21:14 »
while doing the mk4 swap , i did read something i think its on the quattro's you can use 256mm vented's on a mk2 , for the people running five stud i guess ?
Joe
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #18 on: 08 January 2011, 07:51 »
The 4 motion has these as well.. And yer for 5 stud rears
Offline dan_apps
  • too low for british roads!
« Reply #19 on: 08 January 2011, 10:04 »
:afro: things of this nature i always loctitie for that exact reason!
