Author Topic: Turbo Timers  (Read 2366 times)
Offline GaryM
  • Gary
Turbo Timers
« on: 24 August 2003, 23:22 »
Hi
Is it really that harmful to turn the ignition off straight after a journey on a turbo charged engine (speciafically Golf Mk4 1.8T)?
I have seen timer boxes which allow the engine to run on after the ignition has been switched off to allow the turbo more time to cool.
Surely if something like that was needed then it would have been built into the engine in the first place?
Any comments appreciated.
Gary
2003 (53) GTI 180  | Custom Code Phase1 remap (JBS)  | Click for photo's and spec
Offline quickvr6
Re:Turbo Timers
« Reply #1 on: 25 August 2003, 23:29 »
turbo timers are not essential, please have a read of the following extract from turbotechnics website, if you follow this advice you wont go far wrong.
Useful tips when driving any turbocharged engine, whether it be petrol or diesel, are to always allow the engine to warm-up fully, until the water temperature gauge reaches normal, before full throttle is used. Try to plan the end of your journey sympathetically. Don?t use full throttle or allow the engine to labour during the last few miles. This will prevent excessive heat build-up within the turbo when the engine is turned off. Also, when coming to a standstill, try to leave the engine idling for a few extra seconds to allow the heat to decrease. Never rev the engine just as the ignition is turned off. Remember the turbo spins at a far greater speed then the engine, but is lubricated with engine oil. Once the engine stops the oil supply ceases. In reality, none of the above traits will cause a turbocharger to fail immediately, but repeatedly over a long period, they could reduce the life of your turbocharger.
Offline adyh
Re:Turbo Timers
« Reply #2 on: 28 August 2003, 10:39 »
Agreed  ,  the turbo is normally the highest point of  oil pressure in the system. As soon as you cut the ignition the oil pressure drops and leaves your nice turbo spining on with little or no lubrication. If the turbo goes its V expensive.
But as above just treat the car with respect , and when you park just let the revs dies down to idle for a few seconds.
