Author Topic: ko3 turbo's on agu's.. how laggy/slow to spool up is yours?  (Read 4843 times)
Offline The Dave
Just something I wondered, I aint got no gauges or anything to monitor boost but once up to boost it seems fine, however it seems "laggy" compared to a mates ko3s AUM and another pals ko4 TT BAM engine.. I know they're different turbos but regardless, does your ko3 (if you have one) spool very quickly? SHOULD it spool quickly?
I am off to r-tech soon for a TIP, 007p and a health check on the car but want to avoid spending more if poss haha :)
Cheers.
Dave :)
Offline tech1889
  • Mk2 GTI FTW !!
Re: ko3 turbo's on agu's.. how laggy/slow to spool up is yours?
« Reply #1 on: 05 December 2010, 13:57 »
it should spool quite quickly.. they are not very laggy turbo's
Offline golfgtidan
« Reply #2 on: 05 December 2010, 13:58 »
r-tech  good move!  :grin:
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
Offline The Dave
« Reply #3 on: 05 December 2010, 14:01 »
It's a bit weird, the TT I mentioned is mapped to about 260bhp but it spools almost instantly. Custom Code map.
Mates ko3s has a stage 2 Revo map on (Golf, AUM).
Mine has a stage 1 APR map... but as you say with it being a diddy turbo you'd think it wouldn't be laggy. It's more noticable at lower rpm, if you're moving and are up the revs a bit it's not too laggy if you go off power then back on but... tis an odd one.
Hopefully R-Tech can advise me on a couple of things when I go get those bits fitted, they may help of course with spooling also :)
Offline houston
« Reply #4 on: 05 December 2010, 14:04 »
did you have it mapped before you fitted the k03s? i believe you need the ecu mapped to suit the turbo, probably be why your having issues
Offline The Dave
« Reply #5 on: 05 December 2010, 14:06 »
Mines running the ko3 mate... standard turbo, original too on 140k to be fair but no smoke or anything so.. hopefully it's not busted, it's always been like it in the 16 months I've owned the car in terms of a little laggy.
Offline houston
« Reply #6 on: 05 December 2010, 14:08 »
i should really read posts properly, lol
i know what you mean about the turbo difference, i noticed mines a bit slower than my workmates gti, i just put it down to the fact he had a panel filter fitted.
i know the k03s will hold the boost longer so maybe thats it?
Offline The Dave
« Reply #7 on: 05 December 2010, 14:13 »
Possibly...
Only stuff I've done to mine engine/transmission wise (the remap was done before purchase):
- APR remap (done at Awesome for 95 ron fuel)
- NGK Platinum spark plugs
- Pipercross performance panel air filter
- Custom "Stealth" hidden cat-back exhaust, non-resonated
Probably around the 185bhp mark if it's running right? As I say when I get some time off I want to get a Forge TIP and 007p fitted down @ R-Tech and them check it over. It runs well, odd how the small turbo has a bit of lag though lol.
Offline richw911
« Reply #8 on: 05 December 2010, 14:26 »
I would say it is a characteristic of the map  :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #9 on: 05 December 2010, 15:01 »
map = sh!t
