Author Topic: anti freeze  (Read 2286 times)
Offline mattkh
anti freeze
« on: 05 December 2010, 13:34 »
hi
What ratio of G12++ do we need for -20C which is forecast ?
Offline tech1889
  • Mk2 GTI FTW !!
Re: anti freeze
« Reply #1 on: 05 December 2010, 13:37 »
just put in a couple of bottle of g12++ and then add water the stronger the better.
Offline Tazzy
Re: anti freeze
« Reply #2 on: 05 December 2010, 13:40 »
i think the system can hold 3 litres isnt it?
If It Comes Off, Modify It!
Offline tech1889
  • Mk2 GTI FTW !!
Re: anti freeze
« Reply #3 on: 05 December 2010, 13:47 »
just over i think.. i put in 1 and a half bottles of anitfreeze and then topped with water.. ( should use distilled water)
Offline houston
Re: anti freeze
« Reply #4 on: 05 December 2010, 14:02 »
too strong a mix of antifreeze can be very damaging, 50:50 at most. distilled water isnt need either
Offline tech1889
  • Mk2 GTI FTW !!
Re: anti freeze
« Reply #5 on: 05 December 2010, 14:20 »
how you work out it can be damaging ??
Offline topher
  • Administrator
  • fully functioning
Re: anti freeze
« Reply #6 on: 05 December 2010, 14:59 »
Because coolant additives have a low thermal capacity and a high viscosity, the water molecules are the ones taking the heat away from the engine. The glycol in the G12 will gel up and cause overheating/dead waterpumps if used undiluted.
Offline tech1889
  • Mk2 GTI FTW !!
Re: anti freeze
« Reply #7 on: 05 December 2010, 15:01 »
yer i understand that but as long as there is water in there, there shouldnt be a problem.. i didnt say use undiluted just a stronger mixture will withstand lower temps.. no ??
Offline topher
  • Administrator
  • fully functioning
Re: anti freeze
« Reply #8 on: 05 December 2010, 15:12 »
perhaps i should have said "insufficiently diluted" rather than undiluted. The general rule of thumb is more than 50/50 and you're heading for the problems mentioned above.
Offline tech1889
  • Mk2 GTI FTW !!
Re: anti freeze
« Reply #9 on: 05 December 2010, 15:15 »
hmm interesting well i done as said above and tested it with a tester yesterday an it says its perfect for up to -40 or something.. maybe i just was lucky..
