Author Topic: Newbie here and to VW (180HP 6 Speed GTI)  (Read 3395 times)
Offline alexd
« on: 03 December 2010, 13:28 »
Hi all, my names Alex from Portsmouth, for the last 2 years i've been driving a 52 plate 1.4 Civic, and on wednesday i got this delivered:
http://www.purecarmanagement.com/cars/10-volkswagen-golf-18-gti-t-180bhp/
Initial drive made me ->   :grin:
I've identified a couple of problems with the car so far; firstly it does not warm up to 90 unless sat there running, then when i drive down the road the temperature will drop to quater or less. I've read this can cause a couple of problems the main one being my concern is low MPG  :angry:
So i've arranged to go pick up A coolant temp sender after work from my local GSF for £16.50, does this seem a fair price? Will this improve my MPG??
Also planning to smooth my airbox, is this worth it? And where can i get a PiperX panel filter the cheapest from?
Comments and crits welcome on the car, but i love the noise and power of the 1.8T
Hopefully theres some other peeps from pompey here too!!
Alex  :evil:
« Last Edit: 03 December 2010, 14:13 by alexd »
Offline alexd
Re: Newbie here and to VW (180HP 6 Speed GTI)
« Reply #1 on: 03 December 2010, 14:06 »
£16.50 for the temp sender, failing that i will get a new thermostat, I think so, i thought that all 6 speed were 180BHP? Correct me if im wrong and tell me how to check ;)
It's also a parralell import!! If that makes any difference.
Offline Rhyso
« Reply #2 on: 03 December 2010, 15:22 »
Don't think you have a temp sender problem.
Sounds more like the thermostat or water pump.
and replace with some fresh coolant
if it was water pump your gauge would be working overtime  :grin: :grin:
Offline Len
« Reply #3 on: 03 December 2010, 16:16 »
Constant breakdowns do help build knowledge.
Welcome mate.
www.sas.org.uk
www.the-ace.org.uk
Offline alexd
« Reply #4 on: 03 December 2010, 16:21 »
Cheers all =]
Will let you know if the sender works or not!!
Could it just be extremly cold weather? Or should it still warm up correctly? s i havn't even opened her up full chat yet Cause i'm thinkin it's too cold!
Offline Len
« Reply #5 on: 03 December 2010, 16:29 »
This cold weather will give you top performance!  :grin:
As long as you have heat from heater then it should be fine. My Passat 1.8T never gets up to 90
www.sas.org.uk
www.the-ace.org.uk
Offline Cov golf
« Reply #6 on: 03 December 2010, 22:32 »
Welcome to the site
Offline Rhyso
« Reply #7 on: 04 December 2010, 16:29 »
As you know your stuff, is it a 180bhp
Providing the engine code is AUQ - but AFAIK all 6 speed GTI's are the later 180bhp model
Then you got a problem  :tongue:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #8 on: 04 December 2010, 16:58 »
Correct.
Offline GOLF_STU
  • THE_GIT
« Reply #9 on: 04 December 2010, 20:19 »
welcome along  :cool:
V TEC KICKED IN Y'ALL!!!
