Author Topic: ps3 flashing red light  (Read 3799 times)
Offline R32UK
Re: ps3 flashing red light
« Reply #20 on: 30 December 2010, 08:20 »
TRUST ME some games out there kill the graphics chip (baking hot) so the solder melts on them, best bet is get the board reballed with LEADED solder balls and you shouldnt have any probs! other thing i would recommend is get them 3fans that you can plug on the side or something too keep it cooler
where can i find these 3 fans??
Offline daniel-1986
« Reply #21 on: 30 December 2010, 08:31 »
also the fact that ps3 uses a low rpm single fan means it cant get rid of the heat quick enuff, ive taken both the ps3 and 360 apart and think the ps3 is probably the worst design for cooling because iirc the fan sits under the motherboard and it collects a huge amount of dust inside the console
Offline R32UK
« Reply #22 on: 30 December 2010, 12:43 »
thats a good point. mine wasnt anywhere near as bad as some of the pictures seen on the net.. but bad none the less.
found a good fan on amazon that is rated quite highly... unfortunately it is sold out. :undecided:
Offline R32UK
« Reply #23 on: 30 December 2010, 12:44 »
yep.. it appears the heatgun repair is a temp fix!!  :angry:
Was playing gt5 last night and it turned off on me again. On closer inspection the PS3 was pumping out some SERIOUS heat. Tried playing it again a few times and it did the same thing but I was able to turn it back on.
I then switched to Pro Evo and played for an hour + with no problems what so ever.
Without a doubt it is GT5 thats causing the PS3 to over heat!!!  :embarassed:
... just to add it overheated again last night whilst loading the Pro Evo updates  :cry:
Offline sharki786
  • GOT BOOST??
« Reply #24 on: 03 January 2011, 13:51 »
ebay my man http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=ps3+3fan&_sacat=See-All-Categories
one that i say get is http://cgi.ebay.co.uk/Sony-PlayStation-3-Cooling-PS3-Fan-Variable-Speed-/330509087690?pt=UK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN&hash=item4cf3e073ca
i keep my ps3 up right
or a 4 fan http://shop.ebay.co.uk/i.html?_nkw=ps3+4fan&_sacat=0&_odkw=ps3+5fan&_osacat=0&_trksid=p3286.c0.m270.l1313
but best bet is get the board reballed with LEADED solder and it will last over a year if you use it with the 4 fan (the more the fans the more cooler the ps3 will be)
« Last Edit: 03 January 2011, 13:54 by sharki786 »
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline R32UK
« Reply #25 on: 03 January 2011, 16:25 »
in the end i went for this to keep an eye on the new ps3 slim i have.... seems quite good
http://www.logic3.com/details/?prod=788
