Author Topic: Exhaust popping?  (Read 1358 times)
Offline benstanley
Exhaust popping?
« on: 03 December 2010, 00:57 »
Was on my way home tonight, pulled up to some traffic lights and forgot to put my car in 1st when pulling off. As i eased off of the accelerator the exhaust popped  :evil: Just wondered if anyone could shed any light? Standard exhaust, pretty sure its rotten though as it rasps aswell. :drool:
Or is that in itself and explanation to the problem?
Offline Tricky71
Re: Exhaust popping?
« Reply #1 on: 03 December 2010, 01:52 »
mine pops and bangs and i dont want a answer as it sounds good
Offline Tricky71
« Reply #2 on: 03 December 2010, 02:52 »
Timing would cause this problem i think
Offline snifferdog
« Reply #3 on: 03 December 2010, 07:56 »
Mine used to do this, I replaced the ignition coil and it cured it.
« Reply #4 on: 03 December 2010, 08:43 »
ive had this a couple of times, 1 was when the ignition timing was out, and another time when the exhaust had a bad leak
Offline benstanley
« Reply #5 on: 03 December 2010, 13:18 »
ive probabaly got both. Are either of them terminal to my engine?
« Reply #6 on: 03 December 2010, 13:20 »
ign timinbg will loose you power, if way off it wont do the engien any good but usually mk3 ecu puts car into safe mode to avoid damage. zauast leak just makes it sound crap
