Author Topic: No Brake Lights - Problem!!  (Read 3565 times)
Offline benday007
« on: 30 November 2010, 20:52 »
Hi Guys
Hoping someone can help, Ive lost my brake lights (All 3)
Ive had the Brake light switch taken out n tested with a multimeter and Im told that is not at fault! Ive also checked the fuses and thats ok, Checked the bulbs againwith a multimeter and again ok!
Can anyone suggest any other possible thing to check as I need brake lights!!
Cheers!!!
Offline tech1889
  • Mk2 GTI FTW !!
Re: No Brake Lights - Problem!!
« Reply #1 on: 30 November 2010, 20:53 »
s far as i know the fuses in the fuse box are reversed so check all the fuses at that voltage..
Offline benday007
« Reply #2 on: 30 November 2010, 21:07 »
Ok....Just one question, what does the fuse box being reversed mean?
Also I have power at the Brake Light switch so think fuses might be ok?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 30 November 2010, 21:11 »
If the fuse was 2 down and 1 in it would be 2 down and one in from the opposite side if that makes sense ??
If the switch has power than im not sure have you googled it or used search function on here ??
Offline richw911
« Reply #4 on: 30 November 2010, 23:10 »
Faulty wiring in a light cluster?  :undecided:
Offline The Dave
« Reply #5 on: 30 November 2010, 23:11 »
I'd get a new switch anyway...
Offline benday007
« Reply #6 on: 01 December 2010, 09:38 »
Ok I I'll give that a go it can't hurt, I think that that switch is stopping my cruise control
Working too!
Offline Rhyso
« Reply #7 on: 01 December 2010, 09:49 »
Working too!
Nail on head :afro:
Brake Light Switch is about £10 from the dealers  :smiley:
Offline Waffs1984
  • Spacers are for chumps...
« Reply #8 on: 01 December 2010, 11:16 »
^ Yep - i fitted one a couple of months back for my MOT. There's a good guide over on VW Vortex however don't be put off by the paranoia over breaking the new switch when installing it as the one i got was an even newer revision than the one they mention and its fairly idiot proof to fit!
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline Rhyso
« Reply #9 on: 01 December 2010, 11:26 »
