Author Topic: AEX throttle body, high idle issue! 3000rpm with video  (Read 5052 times)
Offline GrandMstRamRod
« on: 30 November 2010, 20:12 »
fitted new throttle body today, and same problem with old one stays idleing at 1.1 thousand revs and then builds up i havent had my car working in two weeks, these are the vag com results!
VAG-COM Version: Release 409.1-US
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01: Engine
   Controller: 030 906 027 T
   Component: MOTRONIC MP 9.0    2119
   Coding: 0261203614
   Shop #: 1037355255
4 Faults Found:
00533 - Idle Speed Regulation
            09-00 - Adaptation Limit Surpassed
00530 - Shareware Version. To Decode all DTCs
            30-10 - Please Register/Activate - Intermittent
00518 - Shareware Version. To Decode all DTCs
01087 - Basic Setting Not Performed
            16-10 - Signal Outside Specifications - Intermittent
Readiness: N/A
Skipping Address 15-Airbags
Address 25: Immobilizer
   Controller: 1H0 953 257 B
   Component: IMMO VWZ3Z0V6271372 V00
   Coding: 09600
   Shop #: WSC 00000
No fault code found.
all these other codes mean
00530 butterfly valve placing he/potentiometers -G88 - can also be throttle posistion sensor
00518 butterfly valve potentiometers -G69
01087 basic adjustment not accomplished
« Last Edit: 01 December 2010, 11:29 by GrandMstRamRod »
Re: AEX throttle body, still broke please help!
« Reply #1 on: 30 November 2010, 20:43 »
basically short story is, cleaned the throttle body, and the motor siezed up on the back so the engine ideled for 30 seconds when started up then revs would build up to 2 thousand and 3 thousand and stay inbetween theses two amounds dropping then going back up again, i knew this was broke as the butterfly valve was jammed open by the motor, when unplugging the cable ontop of the throttle body it would idel correctly.
so i buy one of ebay!
fit this new throttle body today and got these error codes
fitted the new throttle body and put everything back together with the new throttle body, started it after a few
false starts to build up the pressure in the fuel line, and started perfectly after about 10 mins of running same
thing again revs automaticall build up to between 2000 and 3000 and drops and builds up again, if i disconnect
the cable on the top of the throttle body the engine dies as the ecu thinks there is no engine and stops fueling the
engine, so that is difrrent to the last one but the revs keep building up without me pressing the pedal
it has been 2 weeks know and im rather pissed off with it, anyone got any idea please!
« Reply #2 on: 01 December 2010, 00:23 »
any help would be greatly appreciated wanna get her back on the road!
Offline Len
Re: AEX throttle body, high idle issue! 3000rpm with video
« Reply #4 on: 01 December 2010, 13:11 »
Have you checked all the vacuum hoses?
www.sas.org.uk
www.the-ace.org.uk
« Reply #5 on: 01 December 2010, 14:10 »
yh fine mate, i just got told by a golf nutter in my college to check the idle stabalisation valve apparently when they get all sooty the resistance is buggerd so it keep reving then engine
Offline LowlifeDubber
« Reply #6 on: 01 December 2010, 15:50 »
Im sure you need to go into Vag-com>Basic settings and do a throttle adaptation once you have played with it?
« Reply #7 on: 01 December 2010, 15:54 »
yh but the lite version dont let you do that and its 99 dollas for the lisence for the bloody thing
« Last Edit: 01 December 2010, 16:14 by GrandMstRamRod »
« Reply #8 on: 01 December 2010, 21:50 »
Check your pm's dude  :cool:
« Reply #9 on: 02 December 2010, 18:33 »
went out and bout a brand new throttle body 160 quid anyone round chester with full vag com software!
