Author Topic: jetta brakes, poor pressure  (Read 1353 times)
Offline captin_urbis
« on: 30 November 2010, 16:18 »
so picked up my jetta on sunday, front disks/ pads have been changed, not sure about rear. but my brake pressue is very poor. iv taken a look at a servo and its very rusty, along with the master cylinder. im guessing the pressure is due to the rusty servo? so loosing servo asistance. is there anyway i can test that its working? or shall i just replace it?
sorry if i seem like a noob but i sort of am. thanks in advance
car is a 1.6 pierberg jetta tx btw
Offline lemski
  • 16v
Re: jetta brakes, poor pressure
« Reply #1 on: 30 November 2010, 18:22 »
Try bleeding the breaks up 1st as it might just be that
Offline MiniDan
« Reply #2 on: 30 November 2010, 19:10 »
+1 for bleeding brakes.
Old fluid will have moisture in it and make the brakes pony.
Need your car or parts transporting? Engines, wheels, panels, etc. PM me for a quote.
Fully insured and cheap rates. Discount for forum members.
Offline AudiA8Quattro
« Reply #3 on: 30 November 2010, 20:19 »
Have the new brakes bedded in yet?
« Reply #4 on: 01 December 2010, 00:09 »
will give a check tomorrow and see how old fluid is and possibly change it?  erm they were done a month ago? plus a 200 mile trip back up north, surley have embedded in then? again sorry for noob answers am very amature wi brakes...not summert i shouldnt learn though! haha
Offline Neo Badness
  • Feet are for pedals
« Reply #5 on: 01 December 2010, 00:27 »
When you say poor pressure do you mean that you have to press the pedal down further than you used to to get the same result? If so bleed the brakes. Gases are compresible, liquids arent.
As you say you are a noob.
 Do this by starting at the caliper furthest from the servo, usually pass/rear. Get a suitabale bit of pipe that fits over the bleed nipple. Loosen the bleed nipple, get a mate to pump the brakes 10x on the last on hold the pedal to the floor. Tighten bleed nipple NB do not over tighten as you will knacker caliper/ break bleed nipple in caliper which is a PITA. Work you way round drivers/rear, pass/front, drivers/front etc making sure you do not let the fluid drop all the way down in the resevoir otherwise you'll suck air into the system, this is a bad thing.   :smiley:
Another point is to bed in brakes, I personally do this on my cars and hasn't failed me yet. This guide saves me typing it out...
HTH's
http://www.zeckhausen.com/bedding_in_brakes.htm
« Reply #6 on: 01 December 2010, 18:03 »
just had a read. much apreceate the help. will have to wait untill the snow has vanished and when its dry so brakes dont cool by water.
thanks again for the post =]
