Author Topic: Exhaust  (Read 1413 times)
Offline CJ
Exhaust
« on: 10 February 2005, 21:48 »
Anyone ever wrapped new manifold in Heat resistant tape !!!!
What are the benefits ????
Offline Horney
Re: Exhaust
« Reply #1 on: 10 February 2005, 21:55 »
Are you taling about that heat wrap stuff?
If so I've had mixed results with it on the mini. It helps reduce engine bay temp (Good on the mini as the air intake is right above the exhaust manifold) but increases exhaust temperature quite alot. Rolling road results of before and after were negligable.
Offline Gambit
Re: Exhaust
« Reply #2 on: 11 February 2005, 09:59 »
it also passes the heat further down the exhaust so you tend to melt your exhaust hangers unless you get the chained items from C&R
