Author Topic: Has anyone used 235 instead of 225 wide tyres on the standard 17" rims  (Read 1314 times)
Offline dp71
and if so did they make a difference, good or bad?
I have the chance to get either size although the 235's are less costly so I am curious.
Thanks
I would stick with 225's
Offline rudy
did a wee bit of research across various gti forums , advice seems to be stick with 225 , s . for all sorts of reasons , theres not alot of room to play with on a mk 5 so there may be clearance issues , so then u may have to look at offsets to run wider tyres which may lead to clearance issues , stick with 225 its less hassle
