Author Topic: Pump twice to Get a Brake Pedal???  (Read 2997 times)
Offline sill-skimmin'
  • Yes, it does catch. On everything.
« on: 10 February 2005, 19:22 »
Hi guys
Last week i blew the rear driver side brake pipe (the one before the flexi hose)
Since fixing this by replacing the pipe, the brakes are very spongy.
If you slam your foot down on the brake pedal it goes through the floor, same the second time. On the third press, however, something magical happens ; You get the brakes back!!!!!!!!!
Tried bleeding the brakes (all round) this has made it better than it was but still requires pumping.
Checked the valve that runs inline from the servo to the air flow bit at top of engine, you have to suck or blow - air only flows one way, so pretty sure thats OK.
Surely it could only be the servo or master cylinder? Would that mean the brakes wouldn't work at all tho?
By the way the car is a 87 golf mk2 gti k-jet.
Any help you can give would be much appreciated as I am almost going insane   :shocked:
Mark
1987 Mk2 GTi 8v. Full strip out. LUKE harnesses. Drilled Airbox. 14" BBS. Slammed on Coilovers.? Plastic arches fell off. Side of splitter hanging. Weight reduction by 'Rust Motorsport'
Offline Mr Blue
Re: Pump twice to Get a Brake Pedal???
« Reply #1 on: 10 February 2005, 19:27 »
bleed the breaks again. someone on this site should know the correct order to bleed them.
Rain
« Reply #2 on: 10 February 2005, 19:43 »
its longest line to shortest line
Rear Right
Rear Left
Front Right
Front Left
if im wrong someone correct me
Offline ...joe
« Reply #3 on: 10 February 2005, 22:41 »
did you press the brake pressure regulator lever while bleeding? this can be a bit stiff and may need a bit of work to get it moving easily but needs to be pushed back to get a good bleed!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline mk1
« Reply #4 on: 10 February 2005, 22:51 »
There is probably air in one or both or the rear calipers, jack the back of the car up as high as you can get it. Make sure the brake compensator is wedged full open so you get a good flow of fluid from the bleed nipples. Bleed until there is no bubbles and a good pedal, don't let the master cylinder run dry.
Steve.
Offline AudiA8Quattro
« Reply #5 on: 11 February 2005, 00:38 »
Steve.
I'm sure i've posted that somewhere before ages ago  :laugh:
Just to add to that, raise the car up on the rears, press the brake pedal 40 times or more, then leave it to settle for an hour. The theory is if you have jacked the rear up high enough then it should be the highest point in the system, so all the air should settle there.
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #6 on: 11 February 2005, 08:37 »
Did u remember to clamp the Brake bias valve when you bled them ??
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Rain
« Reply #7 on: 11 February 2005, 09:16 »
and if you got all that without your head spinning  :laugh:
« Reply #8 on: 11 February 2005, 12:16 »
Oh and when you pump the pedal do NOT press it all the way to the floor, you'll bugger the seals :)
Buy an 'eeze-bleed' from Halfords, it uses pressure from the spare tyre to bleed the system, makes the job dead easy  :grin:
« Reply #9 on: 11 February 2005, 13:05 »
Think I might go and write myself a bestseller now on brake bleeding!
Thanks for all the help folks, much appreciated.
I'll buy you all a pint...
