Author Topic: Tyre switch/harness retrofit kit from?  (Read 30292 times)
Offline mike.
Re: Tyre switch/harness retrofit kit from?
« Reply #80 on: 27 June 2012, 18:37 »
Here is the place to check the TPMS Button.
You need to go into the ABS controller, then measuring blocks and go to block 16 and hit GO.
When you press the button you should see the NOT Oper.  toggle to Operate.
Also just to make sure that the coding is correct I have included mine as there are two places for TPMS, BYTE 16 and BYTE 17.
Only BYTE 16 being correct.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Buck
  • Das Auto
« Reply #81 on: 27 June 2012, 20:44 »
Thanks Mike
Just in from work so will have a look after food !!
Adrian
Offline Buck
  • Das Auto
« Reply #82 on: 27 June 2012, 22:22 »
Hi
Just checked mine and when I press the switch - nothing happens
I have swapped it with the ESP switch and nothing from that either so it's clearly a circuit issue or something "bigger"
Any thoughts/ideas?
Thanks
Offline mike.
« Reply #83 on: 27 June 2012, 22:59 »
It looks like the wire between the switch and the pin in the ABS controller is not connected,
Did you check the connector at the controller end in case the pin has not located properly?
Offline Buck
  • Das Auto
« Reply #84 on: 27 June 2012, 23:01 »
No I didn't.  Battery out tomorrow night and I'll take a look.
For some reason I've now got my ESP;ABS and TPMS lights flashing on the dfash and can't clear them  :sad:
Offline Buck
  • Das Auto
« Reply #85 on: 27 June 2012, 23:32 »
Hmmm
I noticed today that the warning light (TPMS) was flashing for a few seconds then goes constant. I've run a diagnostics tonight and the following are showing.
Not sure what I've done but I've got a few errors showing now?
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
65-Tire Pressure -- Status: Cannot be reached 1100
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B600D092200FB681206EA901A0082340800
   Shop #: WSC 01357 011 00200
   VCID: 78FA6505CBC86A9
1 Fault Found:
01486 - System Function Test Activated
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 50614 km
                    Time Indication: 0
                    Date: 2030.14.04
                    Time: 23:15:51
             Freeze Frame:
                    Count: 3
                    Count: 6
                    Count: 20480
                    Count: 320
                    Count: 41472
                    Count: 512
                    Count: 0
                    Count: 0
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0573
   Revision: 00103 AF
   Coding: 48180A389025F1C044080080340001E443500088532D8160E48000200000
   Shop #: WSC 07097 500 00200
   VCID: 306A9D256338729
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 13100  21  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 271009 05  54  0402
   Coding: 0730AD
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
3 Faults Found:
00907 - Intervention load Management
            000 -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 184
                    Mileage: 50614 km
                    Time Indication: 0
                    Date: 2030.14.04
                    Time: 23:15:18
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00984 - Left Tail Light (M4)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 50614 km
                    Time Indication: 0
                    Date: 2030.14.04
                    Time: 23:20:50
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 50614 km
                    Time Indication: 0
                    Date: 2030.14.04
                    Time: 23:20:50
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 970 E    HW: 5K6 920 970 E
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 170B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 3666AB3D895C5C9
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 50614 km
                    Date: 2030.14.04
                    Time: 23:14:41
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 221009F2001111
   Coding: E9807F07400612000003
   VCID: 69DC30414062C31
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 50614 km
                    Time Indication: 0
                    Date: 2030.14.04
                    Time: 23:14:08
End   ---------------------------------------------------------------------
Any advice / pointers gents?
Offline mike.
« Reply #86 on: 28 June 2012, 08:49 »
Looks like this may be a result of removing the the ESP switch with the iginition on.
TPMS error is due to enabling the other TPMS system at some time.
The load intervention happens if the ignition has been on for a while or the doors open it usually clears itself.
Not sure what the instruments one is but looks like it only happened once so may be just a blip.
I would just clear the errors down and see if they come back.
You may have to drive the car forward a bit and brake to get the ABS to reset.
Offline Buck
  • Das Auto
« Reply #87 on: 28 June 2012, 19:13 »
Thanks Mike
I've managed to finally sort it - looks like a loose connection in the ABS controller in the engine bay
I'm still left with one error which is the ABS Function Test - I need to take the car on a drive at 13mph and turn the steering between 90 and 180 degrees for it to reset this
~Fingers crossed - update to follow <crosses fingers>
   Revision: 00H30001
   Coding: 163B600D092200FB681206EA901A0082340000
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 50674 km
                    Time Indication: 0
                    Date: 2030.14.05
                    Time: 18:42:42
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 20480
                    Count: 320
                    Count: 42240
                    Count: 64768
                    Count: 0
                    Count: 0
Offline ScottA
« Reply #88 on: 28 June 2012, 19:50 »
Thanks Mike
   Revision: 00H30001
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 50674 km
                    Time Indication: 0
                    Date: 2030.14.05
                    Time: 18:42:42
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 20480
                    Count: 320
                    Count: 42240
                    Count: 64768
                    Count: 0
                    Count: 0
13mph, that's very precise!
Do you have to do it with one finger on your nose and blindfolded too? lol
Good luck  :cool:
Offline Buck
  • Das Auto
« Reply #89 on: 28 June 2012, 20:01 »
^^ I didn't mention that you have to roll your trouser leg up too!
Bit exact is what I thought too - apparantly its equal to 20kmh !!
