Author Topic: Tyre switch/harness retrofit kit from?  (Read 30225 times)
Offline SteveP
Re: Tyre switch/harness retrofit kit from?
« Reply #70 on: 05 March 2011, 21:29 »
Buck, I didn't need to remove the side panels, I found you could feed the wire behind the trim and cable tie it to the ducting for the footwell vents.
Offline Buck
  • Das Auto
« Reply #71 on: 05 March 2011, 23:48 »
Thanks Steve,
Adrian
Offline 09GTI
« Reply #72 on: 19 November 2011, 11:16 »
Hi Steve,
Are you still able to supply the switch and loom for the TPMS ?
Thanks
2014 Mk 7 GTI 5 door , Discover Pro , Pan Roof , DSG , ACC, Xenons , Parking  Sensors  , Rear Tints, KESSY.
Offline SteveP
« Reply #73 on: 19 November 2011, 11:35 »
Yep, once your up to 10 posts then PM me  :smiley:
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #74 on: 19 November 2011, 11:49 »
Some more group buys?
Offline 09GTI
« Reply #75 on: 19 November 2011, 12:43 »
Cool Steve will do I'm nearly there !
Jimmymature
« Reply #76 on: 19 November 2011, 13:16 »
What sort of price would this be?
Cheers,
Jim
Offline Buck
  • Das Auto
« Reply #77 on: 27 June 2012, 01:24 »
As some know, I've not been able to use my reset button in the centre console to remove the dash warning light.
At my last service i asked them just to reset the warning but no, they said it was a faulty switch :( VW replaced TP switch today to no joy and then spent 30 minutes trying to find why it still won't reset.
Tonight I removed all the cloth tape from the harness and checked all wiring back to SteveP's original wiring explanation - check!  I then checked all the connections to make sure they were sound - check!
Sam (Branchespark) has lent me his VCDS cable so again I checked that the coding was enabled - check!
Still can't reset it from the switch :angry:  any ideas before I just turn the thing off to prevent future warning lights appearing?
Offline mike.
« Reply #78 on: 27 June 2012, 08:51 »
In VCDS you should be able to go into one of the measurement blocks in the ABS controller and see the switch output.
Pushing the switch then should toggle the output form open to closed, not sure where it is but I will have a look later for you.
This will confirm that it is is the right pin on the ABS controller and that the switch is working.
Does the backlight work ok on the switch when the lights are on ?
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Buck
  • Das Auto
« Reply #79 on: 27 June 2012, 09:29 »
Thanks Mike
The backlight works ok.
The warning light triggered twice - once when I put my winter wheels on then when I swapped back to the summers so it appears to be able to identify the change in rolling circumference/speed and turn on the warning. It just doesn't want to reset.
