Author Topic: Tyre switch/harness retrofit kit from?  (Read 30201 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: Tyre switch/harness retrofit kit from?
« Reply #10 on: 28 November 2010, 22:32 »
Think so, its from a thread by Darren when he fitted TPMS to his mk5.
http://www.mk5golfgti.co.uk/forum/index.php?topic=7677.0
« Last Edit: 28 November 2010, 22:46 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Snoopy
  • Moderator
  • Geoff.
Mk6 GTI  &  Mk1 GTI
Offline Keithuk
« Reply #12 on: 29 November 2010, 12:15 »
Snoopy you should have the basic TPMS already there you just need to enable it via VCDS. Don't bother with the full kit as it isn't worth the extra cost plus fitting. My Flat Tyre Indicator works perfectly and its the best £35 I've ever spent on the car.  :wink:
http://www.vwwatercooled.org.au/f112/how-retrofit-indirect-tire-pressure-monitoring-5-minutes-7k6-50164.html
« Last Edit: 29 November 2010, 18:36 by Keithuk »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline am1w
« Reply #13 on: 29 November 2010, 12:25 »
Forgive my ignorance. You say a dealer can enable it without the full kit. Will it then show on the MFD if there is a deflation?
Offline SteveP
« Reply #14 on: 29 November 2010, 12:29 »
Yes but you can't reset it yourself without either access to VCDS cable or going back to the dealers.
Offline am1w
« Reply #15 on: 29 November 2010, 12:30 »
Thanks Steve. Thought so.
Highjack:
Any news of the Xenons?
Offline Keithuk
« Reply #16 on: 29 November 2010, 12:34 »
You will hear the beep and the flat tyre light will be lit it will show nothing on the MFD. Now they are quite sensitive I have one tyre that drops 3 psi after about 3 or 4 weeks and the light comes on so a visual check isn't much use for 3 psi. Obviously a visual check is the first thing you do just in case you have a fast puncture.
I just added then link to retrofiting the indirect tyre pressure monitoring system.  :wink:
You will need the Set button in the glovebox to recalibrate it otherwise you have to use the VCDS to do it.
Pushbutton switch for tyre pressure warning centre console black/white
1k0 927 121 C REH - £15.45
or for glovebox switch
1K0 927 121 B REH - £15.45
but I don't know how you get the switch loom?
« Last Edit: 29 November 2010, 12:37 by Keithuk »
Offline am1w
« Reply #17 on: 29 November 2010, 12:38 »
My name is Keith and I'm a 54 years young senior motor vehicle technician at Stoke on Trent College. I've been driving and riding motorcycles for the past 37 years.
WOW!
I bow to thee! :smiley:
Offline mike.
« Reply #18 on: 29 November 2010, 13:20 »
That was the orignal question of this thread which was answered back on Reply 2 by SteveP
Snoopy had already linked to the VCDS procedure on Reply 11.
Why have have you just repeated what everyone else has already said, maybe it was just to summarise the thread   :smiley:
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline mortygt140
« Reply #19 on: 29 November 2010, 14:32 »
Has Snoopy said I have done his many moons ago, its very easy to do and the hardest part of it is getting the plug out of the abs module :sad:
In all its quite a good little mod, but don't rely on it cos its not the most accurate thing.
Darren
