Author Topic: Rear Brake Sticking since 'the big freeze'  (Read 1144 times)
Offline james14100
« on: 28 November 2010, 20:09 »
Hello everybody!
Like the title says - my OSR brake has been sticking on ever since the freeze set in. Any idea what it might be cos it's killing my brakes and power lol
James
Offline whitey82
Re: Rear Brake Sticking since 'the big freeze'
« Reply #1 on: 28 November 2010, 20:17 »
I had same problem this morning,from what I've read water gets in the hand brake cables and rusts and freezes. Idealy replace cables and sheaths but I got some silicone spray on the rear calipers and down the cables inside the car under the handbrake and mines fine now  :smiley:
« Last Edit: 28 November 2010, 20:19 by whitey82 »
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #2 on: 28 November 2010, 20:55 »
this most be a common problem when its frozen mine started yesterday i will disconnect the handbrake cable if thats the case
« Reply #3 on: 29 November 2010, 10:32 »
next time it happens look at the caliper under the car. if the cable is still tight its water in the cables, replace em. if its slack its the caliper itself seizing up, replace it
Offline james14100
« Reply #4 on: 29 November 2010, 12:11 »
Cheers guys. I left the handbrake off last night and left it in gear - no sticking today. I think i'll just replace the cables if thats what it is - no point messing around with it as the handbrake isn't the sharpest anyway so I'm guessing it needs doing anyway
James
Offline whitey82
« Reply #5 on: 29 November 2010, 19:36 »
mines bloody siezed again tonight,think il just avoid using the handbrake until ive replaced the cables,only had the car 3 days and learnt so much already as i had problems within a couple of hours of buying it lol, this site is god send to me!!
Offline craigus
« Reply #6 on: 29 November 2010, 21:39 »
mine did same earlier, only siezed for about 5 mins, bit of harsh driving and it sorted it, will check it when weather gets a bit better
  • my golf gti mk3
« Reply #7 on: 29 November 2010, 21:42 »
that will be april then  :grin: :grin: :grin: :grin: just dont touch the handbrake leave it in gear over winter problem solved  :smiley:
