Author Topic: oh SH*T no anti freeze  (Read 29658 times)
Offline Ben Lessani
Re: oh SH*T no anti freeze
« Reply #60 on: 06 December 2010, 15:14 »
i never said it was vw
Nor did I, merely stated as brand new cars
Pfft. all cars are trouble, regardless of age! I had the fun of a giant airlock on the Mini this morning, it was like a snorting bull with the steam venting out the front corners of the rad!
Offline paul69
« Reply #61 on: 06 December 2010, 16:06 »
Haven't had my car long and I don't know what state the coolant is in. I haven't got time to drain coolant now, are those testers accurate?
Offline clipperjay
« Reply #62 on: 06 December 2010, 16:15 »
Paul can you feel the pipes are they solid?
If not you are going to be ok proberly!
If they are solid I would not attempted to start it untill it thaws out by itself. Sometimes people will try and thaw it out with hot water and the like but can cause more issues due to contraction and expansion of ice and water!
Offline Ben Lessani
« Reply #63 on: 06 December 2010, 16:39 »
Yup. The MachineMart one is the better product though.
Ps. If the pipes are solid, you really should pressure test the system, check for risen core plugs and check the condition of the waterpump bearings/impeller before even thinking of starting.
Offline daniel-1986
« Reply #64 on: 07 December 2010, 10:15 »
my car was just running on water last yr, no anti freeze at all in the system. the bloke who did the headgasket was suprised i got thru winter without buggering the engine
Offline Sam
  • Sam I am
« Reply #65 on: 07 December 2010, 16:46 »
MINE HAS FROZEN UP!!??? WHAT THE f**k!?
 :cry:
So what do i do? Pour warm water into my expansion tank or what!? Im sh!tting myself right now
« Last Edit: 07 December 2010, 16:53 by caistor_bmx »
Offline Ben Lessani
« Reply #66 on: 07 December 2010, 16:57 »
... You really should pressure test the system, check for risen core plugs and check the condition of the waterpump bearings/impeller before even thinking of starting.
Offline Sam
  • Sam I am
« Reply #67 on: 07 December 2010, 17:00 »
Right, just been out to check as well as i can, and the bottom feed into the water pump is squishy and the top one isnt quite solid (you can crush it easily)
So im thinking warm stuff? As there isnt 'solid' ice anywhere???
P.S Where are the core pugs? on the back or front of the block?
« Last Edit: 07 December 2010, 17:13 by caistor_bmx »
Offline Ben Lessani
« Reply #68 on: 07 December 2010, 17:13 »
No. The problem isn't melting the ice, its the damage it has done!
Offline Sam
  • Sam I am
« Reply #69 on: 07 December 2010, 17:36 »
Right, got my head screwed on again now so lets start again.
Been out just now and took off the bottom pipe which let out lots of slush, so i can assume for now that the waterpump is drained. I also undid the top pipe to reveal a rad full of ice.
Where abouts are the core plugs on a 16v engine, had a look about with my phone but couldnt really see propperly but nothing seemed to be pushed out of place. I can only assume this means one of two things...
a: the block froze and didnt push the plugs out (or what i think are the plugs)
b: the block isnt fully frozen
 :embarassed:
