Author Topic: oh SH*T no anti freeze  (Read 29607 times)
Offline Sam
  • Sam I am
Re: oh SH*T no anti freeze
« Reply #40 on: 01 December 2010, 14:17 »
You should have VAG G12 in there anyway, shouldn't you :rolleyes: 50/50 and change every 4 years.
Why should I have this exact stuff in it? Does it make much of a difference. I always thought anti freeze/coolant was as simple as it gets. Stops water corroding the paths on the block and stops it freezing/boiling off?  :embarassed:
Offline Ben Lessani
« Reply #41 on: 01 December 2010, 14:20 »
Better longevity, designed to work with the car, scene points etc.
Its only about £8 for 1.5l - which will mix down to about 4l (-30 degs), well worth it for genuine VAG coolant.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #42 on: 01 December 2010, 14:21 »
there is scene coolant lol
Offline Sam
  • Sam I am
« Reply #43 on: 01 December 2010, 14:28 »
Is there anywhere scene i should get the water to mix with it? Can I import it from Wolfsburg?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #44 on: 01 December 2010, 14:35 »
wolfsburg evian FTW !!
Offline Ben Lessani
« Reply #45 on: 01 December 2010, 14:36 »
Probably :D
But on serious note, use G12 - not cheap tat, another bonus is that it acts as a repellent for "oh SH*T no anti freeze" threads.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #46 on: 01 December 2010, 14:38 »
my mk4 has g12++ is this the same ??
Offline Ben Lessani
Offline Sam
  • Sam I am
« Reply #48 on: 01 December 2010, 14:43 »
Probably :D
Note taken Mr Ben, but I'm not changing it in the madness that is the white carpet of freezing death
Offline clipperjay
« Reply #49 on: 01 December 2010, 14:43 »
Anti freeze is Anti freeze the more important part is the water should be distilled water so you don't have minerals impurities growing in your rad  :wink:
Trick is to get 50/50 in a coke plastic bottle and shake it well so it mixes better, which is better than pouring neat Anti-freeze then water or vice versa!
