Author Topic: Engine temp  (Read 2275 times)
Offline thebassman
Engine temp
« on: 28 November 2010, 16:24 »
Bit of a noobie question.
Is the temp gauge on the left hand side, under the rev counter, water temperature?
Is the temp shown in the dash computer display oil temperature?
Do they normally read the same?
Thebassman
Offline dom
  • Back in a Mk4
Re: Engine temp
« Reply #1 on: 28 November 2010, 16:39 »
MFA = Oil Temp
Temp Gauge = Water Temp
When warm my oil temp can be anywhere between 98-104 depending on the type of driving and water temp is usally smack bang in the middle (90 I think).
Offline thebassman
Re: Engine temp
« Reply #2 on: 28 November 2010, 16:49 »
That weird, I had been driving for about half an hour, quite hard.
The water temp was about 70'ish and the oil temp was 74.
Offline whitey82
Re: Engine temp
« Reply #3 on: 28 November 2010, 17:15 »
I've got same problem with gauge sat on 70 all the time and occasionally moving so I've ordered a new temp sender,hope that cures it
Offline dom
  • Back in a Mk4
Re: Engine temp
« Reply #4 on: 28 November 2010, 17:22 »
Have you tried changing the thermostat?
Offline whitey82
Re: Engine temp
« Reply #5 on: 28 November 2010, 17:26 »
No I haven't,only had the car 2 days but read that the water temp sender is a commen fault so for sake of 8 quid thought id give it a go. Where abouts is the thermostat and is it easy to replace? What's the cost,cheers
Offline dom
  • Back in a Mk4
Re: Engine temp
« Reply #6 on: 28 November 2010, 17:33 »
The thermostat is only a few pounds, where it is depends on which engine you have? and how easy it is depends on whether or not you have PAS?
Offline whitey82
Re: Engine temp
« Reply #7 on: 28 November 2010, 17:58 »
It's a 2.0 8valve with pas
Offline dom
  • Back in a Mk4
Re: Engine temp
« Reply #8 on: 28 November 2010, 18:14 »
The thermostat is located by the waterpump, if you look from above you'll be able to see it to the left of your pas belt/alternator belt.
I read somewhere that you can tell if its your thermostat that is faulty by feeling the pipes above and below the thermostat housing when the engine is warm, if both pipes are warm there is no problem but if only one pipe is warm the thermostat is not opening and therefore shot. The theory behind that is good but whether or not it's true I don't know!  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Engine temp
« Reply #9 on: 29 November 2010, 07:54 »
as mentioned above, change the thermostat. Id personally change the pas, auxillary belt and water pump whilst they're stripped out as well for good measure and to save having to do the job twice.
