Author Topic: hazard / warning light help! !!  (Read 1308 times)
Offline gtti_234
« on: 28 November 2010, 13:07 »
On my agu i have a red warning light comming up in the middle of the dash and it keeps beeping at me. It then disappears and comes back two mins later and starts beebing at me again has anyone got any ideas? cant get hold of vag com at the mo due to spending all my day time at work cheers guys.
spax coil overs, 18ins rs8 alloys,007 forge dv,n75j,piper cross induction, r-tech stage 2 remap, custom chromes decat exhaust + 3" down pipe, forge actuator g60 flywheel vr6 clutch, forge tip, deleted pvc catch can install,
Offline T_J_G
Re: hazard / warning light help! !!
« Reply #1 on: 28 November 2010, 13:16 »
Is it a circle with an exclamation mark?
Offline richw911
« Reply #2 on: 28 November 2010, 13:30 »
As above sounds like the handbrake switch  :smiley:
Offline gtti_234
« Reply #3 on: 28 November 2010, 14:49 »
Ye thats the one mate. i just took it in to my local garage with that light on a week ago and whilst my clutch was being done they reset the abs light and the red warning light. The abs light has stayed off but the warning light has reapierd could it be anything to do with the abs?  cheers.
Offline richw911
« Reply #4 on: 28 November 2010, 18:08 »
Do you have the red trip display in the center of the clocks?
The reason i ask if you do and the handbrake switch is faulty it will say "Hand brake on" on the display.
If you don't it just beeps and the light will be on obviously  :smiley:
Offline MickeyC
  • Mk4 GTI 1.8T
« Reply #5 on: 28 November 2010, 18:11 »
check your brake fluid level
Offline richw911
« Reply #6 on: 28 November 2010, 18:15 »
Indeed That should have been the first thing to check  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 28 November 2010, 20:58 »
I reckon the switch on your handbrake is sticking
Offline richw911
« Reply #8 on: 28 November 2010, 21:36 »
Yep my thoughts  :smiley:
