Author Topic: Y is it tht my rear wiper does not wrk????  (Read 2212 times)
Offline rfn_hodgson
« on: 27 November 2010, 23:31 »
any ideas???/
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Re: Y is it tht my rear wiper does not wrk????
« Reply #1 on: 27 November 2010, 23:54 »
Remove the panel inside the tailgate, pull the plug off the motor and see if you have power.
If so the motor has burnt out if not fuse or switch.
Hope this helps
Wayne
« Last Edit: 28 November 2010, 00:00 by Wayne »
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #2 on: 27 November 2010, 23:59 »
+1 exactly the options you have should take you 10mins to find the problem  :smiley:
Offline rfn_hodgson
« Reply #3 on: 28 November 2010, 12:25 »
cheers fellas :)
« Reply #4 on: 29 November 2010, 10:29 »
do you hear the wiper relay click when the rear wiper is activated? does the rear washer work? look in the rubber boot to the tailgate for damaged wires
Offline rfn_hodgson
« Reply #5 on: 30 November 2010, 20:00 »
the squirter works but there no motion from the wiper
Offline *Jonnyg*
« Reply #6 on: 01 December 2010, 00:27 »
Snap!
** Tuned diesels - kinda like a guy with a huge cock and premature ejaculation. **
« Reply #7 on: 01 December 2010, 13:29 »
Have you checked for power at the motor if so the motor has died.
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #8 on: 01 December 2010, 13:38 »
broken wires in the rubber pipe thingy between the roof and bootlid??.I need to investigate the wifes intermittent rear demister not working and suspect this area to be at fault
Offline Gash
« Reply #9 on: 21 December 2010, 23:15 »
if you need a new motor iv got mine which i no longer use. :)
