Author Topic: Oh dear I've made a mess - worn hex bolt (pic)  (Read 2245 times)
Offline RossyB108
« on: 27 November 2010, 18:28 »
Hi,
I got the below drain bult undone the other day no problems to replace the gbox oil. Just bought some Redline MTL to replace the Gbox oil again, but can't get the bolt undone!
I was using a 17mm wheel nut and a spanner which worked dandy the first time but have made a right mess of it today!
Any ideas?
Thanks
Offline tech1889
  • Mk2 GTI FTW !!
Re: Oh dear I've made a mess - worn hex bolt (pic)
« Reply #1 on: 27 November 2010, 18:50 »
drill it out.. or easy out..
Offline Ben Lessani
« Reply #2 on: 27 November 2010, 18:51 »
Go and buy a proper tool, GSF sell a cheap Draper kit with various shapes and sizes in it for about £5.
You might get away with the proper tool still, failing that, its mole-grips and swearing or hammer and chisel.
Offline Sam
  • Sam I am
« Reply #3 on: 27 November 2010, 18:55 »
Nah man, just hammer on the next size up
Offline Ben Lessani
« Reply #4 on: 27 November 2010, 18:59 »
How, the next size is 19mm ... and its not hammer ON, its hammer IN - he'd just end up cocking up the threads on the gearbox, or cracking it at worst.
Offline UKjarvis
« Reply #5 on: 27 November 2010, 19:40 »
If you can get a hacksaw to the bolt hack a grove into it the get some tough steel or really wide screw driver to make it act like a screw or failling that you can get a reverse tapping kit simply drill a hole I suggest a slow speed with plenty of lubricant wax works quite well then insert the tool into a drill and the rest is simple. I think at worst take it to a garage they'l have a tool for it I bet they see this loads. anyhow good luck pal.
Heres a link of what im on about these particular ones have the drill attached, worth the buy there always handy.
http://www.amazon.co.uk/BOA-Bolt-Remover-Kit-Piece/dp/B000Y8IPY6
Offline mwep201081
« Reply #6 on: 27 November 2010, 19:42 »
hammer in a torx bit if that don't work then drill it.
Offline RossyB108
« Reply #7 on: 27 November 2010, 19:44 »
Thanks, sound suggestions.
What about an imperial size set - is there a size slightly bigger than 17mm in imperial that I could tap in?
Not sure where I'll find a large torx set?
Also,  when I get it out does anyone know where I'll find a new replacement one?
GSF do tools  as well! Magic.
Offline UKjarvis
« Reply #8 on: 27 November 2010, 19:51 »
http://www.annalexbute.co.uk/products.html  give them a ring thier really helpfull and stock most bolts.
Offline Ben Lessani
« Reply #9 on: 27 November 2010, 20:12 »
Just get the right tool before doing anything stupid.
