Golf mk2
Gearbox drive shaft leak/loose! (Pic)
Topic: Gearbox drive shaft leak/loose! (Pic) (Read 2196 times)
RossyB108
27 November 2010, 18:23 »
Hi,
Can anyone have a look at the pic below and tell me what's going on here?
I can see it's leaking, but I'm not sure if it has come free or if that much of the green plastic should be showing?
Is it dangerous if it is loose? Not worked with gearbox/driveshafts before.
Thanks
Ross
Ben Lessani
The poor mans MK2 Haynes author
Re: Gearbox drive shaft leak/loose! (Pic)
27 November 2010, 18:49 »
Clean it up, including the area above, and make sure its not engine oil leaking from the block itself. Then re-visit after a few days.
It could be moly grease from the output flange that has flicked everywhere - difficult to say without cleaning it.
RossyB108
27 November 2010, 19:44 »
Will do, thanks.
Wayne
Sir Postalot
27 November 2010, 20:52 »
As ben said clean it up and then see what happens.
AudiA8Quattro
Forum addict
28 November 2010, 12:10 »
What does the oil smell like?
leigh_harty
Audi AGU
28 November 2010, 12:22 »
Quote from: AudiA8Quattro on 28 November 2010, 12:10
Are you refering to the horrendous smell off g/box oil?
Dont lose your dinosaur!
RossyB108
Reply #6 on:
17 October 2011, 13:17 »
Just giong back through some old posts to update.
Cleaned it up and it has been free from oil since. thanks
Golf mk2
