Author Topic: Is this normal?  (Read 1768 times)
Offline simon20vt
Is this normal?
« on: 27 November 2010, 17:46 »
2001 AUM Golf Gti 1.8t, just had the lambda changed as it was bank 1 running rich, and new coilpack, but i'm still getting a problem when accelerating normally, most notably obvious in first gear  :sad:
When you accelerate normally, (not hard, but not really gently) at about 2000 rpm, acceleration slows, and then picks up again. it is enough to throw you forward a little in the seat (e.g whilst leaning on the backrest, if the acceleration slows, you move forward off the backrest of the seat a little)  it doesnt do it everytime, but happens quite frequently. can be quite embarressing with passengers when they are thrown foward a little  :embarassed:
it is also noticable in second gear too at a similar sort of rev range, but just not as much throwing you forward. I though this could have been due to the overfuelling, but obviously not. There arent any other mechanical errors showing on diagnostic check. could this be a slightly faulty MAF, or a dirty throttle body, maybe something else, or might it be the fact that an oil breather has split? The turbo is also on its way out as the seals are leaking, and there is some play in the shaft, but it doesnt happen anywhere near when it starts boosting, so i wouldnt have thought it was anything to do with the turbo. Does anyone have any suggestions/help/advice?
Cheers  :smiley:
Offline tonyg123
Re: Is this normal?
« Reply #1 on: 27 November 2010, 17:57 »
Exactly the same as my car mate,  changed the temp sensor, whilst doing so I noticed that the breather hose had split so replaced that too, was ok for a short time but it happens again every now and then, Im going to clean the Throttle Body in the morn to see if its that. from what I read it is, but fingers crossed!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Is this normal?
« Reply #2 on: 27 November 2010, 18:08 »
my money is on PCV system  :wink:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Is this normal?
« Reply #3 on: 27 November 2010, 20:38 »
+1 i recon its pcv system.
Offline simon20vt
Re: Is this normal?
« Reply #4 on: 27 November 2010, 23:55 »
what do you have to do to fix the pcv system, which part - i dont really know much about the pcv system or what it does? how much is it going to cost est.?
Offline 2001gti4
Re: Is this normal?
« Reply #5 on: 29 November 2010, 10:25 »
Search on here for PCV system boost leaks or catch can. If you're going to replace PCV pipes with OEM ones you may as well go the catch can route for all the extra it'll cost....
My Golf is dead but at least I have this....
Offline tech1889
  • Mk2 GTI FTW !!
Re: Is this normal?
« Reply #6 on: 29 November 2010, 11:27 »
New pcv pipes are £40 each some of them.. I fitted a catch can for £120 and it will never have a problem again..
Offline simon20vt
Re: Is this normal?
« Reply #7 on: 29 November 2010, 12:44 »
what's a catch can?
Offline rio_gti
Re: Is this normal?
« Reply #8 on: 29 November 2010, 13:44 »
i also get this "loss of power" its like the boost comes off between 2500-3100 rpm in second and thurd gear.  only happens prob once in 15 gear changes.
i did clean the trottle body which was a little dirty but the problem is still occuring!!??  :undecided:
could this be the pcv system too???
sorry- dont mean to steal the thred!!!
Offline 2001gti4
Re: Is this normal?
« Reply #9 on: 29 November 2010, 16:00 »
A lot of MK4's suffer leaks in the PCV system due to the OEM pipes perishing. You can either replace them like for like or for around the same price you can replace with silicon hose and a catch can. This means you've less chance of suffering leaks and the nasty aerated oil can be emptied away rather than being recirculated into your turbo.
Use the search facility and look for PCV and/or catch can, there's been a number of threads posted about it.
