Author Topic: VR6 01M Auto transmission info if your interested :)  (Read 616 times)
Offline mk3bummer
just changed the filter and fluid on my vr6 auto with the o1m trans. To fill i used a small length of hosepipe with a 3/8 socket snugged into the pipe , this is a perfect fit then insert into fill tube. At the filling end pop a 16mm socket into the neck of a plastic bottle and attatch the hose. slich the top of the bottle off and you have a fill pipe.  I also did this without vag.com by feeling the under belly of the pan for the same temp as the washing machine on a 40 degree wash. it worked.  super happy.
comments invited. :smiley:
