Author Topic: Oil on boost pipe  (Read 2046 times)
Offline ian007miles
Oil on boost pipe
« on: 27 November 2010, 16:09 »
Hi every one.  I was under the bonnet of my golf 18T AGU.  today and I noticed that my blue forge elbow boost pipe that comes off of the top of the turbo to the intercooler pipe was a different colour to all the other blue pipes I've got, it looks realy dirty. so I wiped it with a clean dry tissue and wen I looked at the tissue it was covered in oil. It is comng through the pipe its self.Does anyone no wot can cause this and could it cause damage to the turbo or the engine thanx ian.
« Last Edit: 27 November 2010, 17:04 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline ian007miles
Re: Oil on boost pipe
« Reply #1 on: 28 November 2010, 18:41 »
Any one
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 28 November 2010, 19:22 »
it shouldnt be able to come through the pipe itself
Offline ian007miles
« Reply #3 on: 28 November 2010, 20:15 »
Thats what I fort. But there's nuffin above it. So I took the pipe off and it's oily inside as well. Do u no wot can cause it.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 28 November 2010, 20:23 »
the inside will be oily because of crappy pcv system only way to stop is with a catch can..
not sure on outside tho mate sorry..
Offline ian007miles
« Reply #5 on: 28 November 2010, 20:27 »
What if I fit a catch can it will stop the oil in Side the big elbow at the top of the turbo
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 28 November 2010, 20:49 »
yes yes.. as the pcv system seems to recirc it via the turbo.. this also means cleaner inside of turbo  :smiley:
Offline ian007miles
« Reply #7 on: 28 November 2010, 21:12 »
Ok fanx mate I will order one.  which one do u recommend
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #8 on: 28 November 2010, 21:20 »
i paid £90 for one from america as it looks oem unlike others.. you can get a cheap on from ebay
Offline ian007miles
« Reply #9 on: 28 November 2010, 21:34 »
Have u got a link to it and does it come with every thin to fit it
