Author Topic: Washers stopped workin,  (Read 2008 times)
Offline beechymonza
  • mad beech
« on: 27 November 2010, 11:41 »
Totally amazing isnt it, They been working fine all year an now bad weather comes they stopped working,
No guts No glory,
Offline Jimmy Filth
Re: Washers stopped workin,
« Reply #1 on: 27 November 2010, 11:42 »
sounds like they're frozen to me.
7R 5 door.  Limestone Grey.  19" Pretoria's, Leather, DCC, Winter pack, keyless entry, rear camera.
Offline emery1990
« Reply #2 on: 27 November 2010, 11:54 »
Same, mine on the van was frozen, even though its got washer fluid in it, must of mixed it with water or something! When its warmed up, then get all the water out and get washer fluid with anti freeze init. youll have to dilute it though!
Offline beechymonza
  • mad beech
« Reply #3 on: 27 November 2010, 12:20 »
Nah they ay frozen, Cause the wipers ay movin neither when i use the washers, :cry:
No guts No glory,
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 27 November 2010, 15:14 »
Stalk or relay...
For More Info Click To See;
Offline beechymonza
  • mad beech
« Reply #5 on: 27 November 2010, 15:26 »
Yeah could be, Just took all cowling off and it all seems ok, But i gotta watch what im doin now as i noticed MFA stalk has got a split in it from me keep pullin it back 2 get it 2 work,
Looks like stickin them on a switch of some kind til new year
No guts No glory,
« Reply #6 on: 29 November 2010, 10:57 »
do the wipers work normally? if so its the stalk or the motor.
gixer1400
« Reply #7 on: 29 November 2010, 17:19 »
if the wipers were frozen could have blown the fuse  :rolleyes: but you probably checked that already
 :embarassed:
Offline beechymonza
  • mad beech
« Reply #8 on: 29 November 2010, 19:46 »
Yeah the wipers are working normally,
They just dont activate when i pull back 2 use washers,
There is only 1 fuse for wipers isnt there, And not a seperate 1 for the washers,
No guts No glory,
« Reply #9 on: 30 November 2010, 10:00 »
hmm so the wipers and pump dont activate when you pull the stalk? if so this is pretty much only going to be a stalk issue. if you take off the stalk surround you might be able to see the washer contacts in the side of the stalks, buff up and a tweak so they make good contact may be all that is required.  I did this on my 83 cabby and problem solved, but I cant remember if mk2 stalks are the same
