Golf mk4
Wazzzer
blew a gasket today!!!!!!!
Topic: blew a gasket today!!!!!!! (Read 1457 times)
0141kyle
26 November 2010, 20:45 »
was driving a bit harsh today an ended up with a loud air like escaping sound when puttin the foot down had a quick look and noise is coming from either the exhaust manifold or the turbo gasket!!!
looking to see if anyone has had this problem and was it a big job to sort have been told it would be easier to take the engine out to replace these gaskets
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: blew a gasket today!!!!!!!
26 November 2010, 21:13 »
both can be replaced in situ, just done mine this weekend when I changed the actuator over. You might have cracked the manifold, quite common
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
0141kyle
26 November 2010, 21:30 »
not totally sure yet gettin it on the ramp on wed to get a better look will be better just to replace all the gaskets while am there any idea how much a gasket set is?
Purely VAG
27 November 2010, 00:01 »
Depends what engine?
✉ Jrd@PurelyVAG.co.uk //
www.PurelyVAG.co.uk
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
27 November 2010, 18:05 »
no more than a tenner mate. Don't forget the manifold nuts are "use once" too.
It's not that easy doing them in situ, you need a bit of guesswork to get to one of the manifold nuts as you can't see it. Also you need to drop the turbo down slightly to gain access to it. Just undo the bolt on the stabiliser bracket and you'll have enough room to get a ratchet in there. Easier than dropping the engine out though
Golf mk4
Wazzzer
