Author Topic: Well and truly f**ked off!  (Read 2952 times)
Offline Mitching
« on: 26 November 2010, 18:12 »
On the way home today, all was good but then I went to overtake a lorry, it felt weird there wasn't the usual power, hardly any pull  :undecided:
Then 2 minutes down the road it just cut out without warning, rolled to a stop and tried to start it again but nothing. All the electrics worked, turned the ignition and I heard all the usual whirring of pumps etc, but nothing from the engine  :undecided:
Matey from RAC turned up and I stuck it in 1st while he rocked it back and forth, it didn't move much and I could see the engine wobble when it went backwards.
He reckons it could be the bottom end seized  :cry:  :sick:
The top end was fine apparently  :sad:
What would be recommended, get it fixed ie new bottom end or an entire engine swap (8v gti digi)?
I know a mechanic that can do stuff cheap for me, only charged £120 to fit the clutch.
« Last Edit: 26 November 2010, 18:23 by Mitching »
Offline Organisys
  • Old and Slow...
Re: Well and truly f**ked off!
« Reply #1 on: 26 November 2010, 18:27 »
Is the engine definitely getting fuel ?
Offline Mr Blue
« Reply #2 on: 26 November 2010, 18:34 »
Electrical fault around the starter motor, igintion area?
If its the bottom end seized then there is a mk2 breaker in leighton buzzard with a few lumps still in the cars.
Know the one? :smiley:
Offline Mitching
« Reply #3 on: 26 November 2010, 19:11 »
How would I test for those faults?
I think so Mr Blue, I think theres one in Hockliffe that does German cars, and also Bennies (the garage in town) have had a few in the past.
Also been on ebay, few on there, one being in Wycombe where I go to uni and my sisters ex works at a breakers in Aylesbury, he's gunna have a look tomorrow so I'm spoilt for choice if it comes to it  :huh:
Offline Mr Blue
« Reply #4 on: 26 November 2010, 19:34 »
One off grovesbury road. plenty of mk2's laying around :lipsrsealed:
Sadly I work in Aylesbury and drive through leighton on a daily
Let me know what you find.
Can pass through yours and see if i can get it running on monday?
« Last Edit: 26 November 2010, 19:36 by Mr Blue »
Offline Mitching
« Reply #5 on: 26 November 2010, 19:50 »
Ah didn't know about that one, live just round the corner from there.
I think the RAC bloke told me about it, is it by route 66 diner?
I'm supposed to be in uni monday, if I cant arrange a lift you're more than welcome to drop by, I won't be going anywhere!  :wink:
If you PM your number I can text you closer to the time to sort summat  :smiley:
And I think I might have seen you drive past a few weeks ago (maybe a month or so?), you got a blue mk2 with a bit of poke? I was at the stop junction in Beirton...
Offline Mr Blue
« Reply #6 on: 26 November 2010, 19:54 »
yep that was I  :smiley:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #7 on: 26 November 2010, 20:31 »
You could always do it yourself. Complete rebuild that is.
Just follow the engine rebuild video for the 8v in the garage section.
Simples.  Then you know it's all good.
« Reply #8 on: 26 November 2010, 21:36 »
Put a bar on the bottom pulley and see if will turn over.
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 26 November 2010, 23:24 »
Sorry, thought this was Stink posting.....
Perfect excuse for a 2.0 bottom end.
Much easier to come by.
