Author Topic: What power increase  (Read 4327 times)
Offline GolfDan
What power increase
« on: 09 February 2005, 21:28 »
will a race cam and 4 in 1 manifold give me (approx) on my 91 8v its fairly quick at the mo but the local civic boys need blowing out of the water completely
Dan
Offline Dizzie
  • Make friends with your fast
Re: What power increase
« Reply #1 on: 09 February 2005, 22:40 »
10bhp if you're lucky. Fit nitous :wink:
Offline piggy
  • What you lookin' at sonny?
« Reply #2 on: 10 February 2005, 01:03 »
You know your stuff Dizzie.
Is that a shorter faster version of Nitrous? :laugh:
 :wink:
Offline Gambit
« Reply #3 on: 10 February 2005, 13:26 »
a race cam will make the car undriveable in normal day to day driving
Offline gibby
« Reply #4 on: 10 February 2005, 13:38 »
Out of interest, why ? What's the difference ?
......now officially dubless.
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #5 on: 10 February 2005, 13:50 »
A race cam has the cam profile engineered for power @ high revs ... imagine a car with no power till 5000 rpm then it wanting to rev like nutter till 9000 rpm upwards!
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline gibby
« Reply #6 on: 10 February 2005, 14:02 »
I see. Thanks for the info Mr H.  :smiley:
Offline GolfDan
« Reply #7 on: 10 February 2005, 14:43 »
i see a rethink is in order then!!  :embarassed: what would you recommend to go with the 4 2 1? thanks for the advice so far chaps
Offline ...joe
« Reply #8 on: 10 February 2005, 22:57 »
get a decent air filter in your standard air box, with all the crap taken out of it if you haven't done that already. open the air box and you should see a trumpet (i'm assuming its a digifant by the age) thingy throw it away and then take a big drill and drill some big holes wing side (ONLY) of the box. thats a start. then get a decent exhaust to go with your manifold, then ported head, then cam then have it blueprinted..... it goes on and on...... !!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline tinman
« Reply #9 on: 11 February 2005, 00:59 »
errrm, not quite.
the "normal" driving becomes a pain cause the engine is rough as nails until you reach a high rev. you can expect idling to be >2000rpm, which makes the car especially painful in town.
you can run any motor up to 9000rpm, you just need to change the return springs on the valves. the reason that engines have a rev limiter is because the the valve generally wont shut fast enough, causing an overlap, and then hell kinda breaks loose. by putting a stronger return spring in place, the valve snaps shut that much faster. thereby allowing you a higher rpm without blowing the engine away.
forget drilling airboxes and the like and changing the exhaust.
generally, get yourself a new standard exhaust, get the air filter changed, and renew the injectors. far simpler and much better results than faffing around in the engine bay for weeks.
if that doesn't work. buy a 16v.
