Author Topic: Right guys another bad question for yas :)  (Read 4314 times)
Offline tech1889
  • Mk2 GTI FTW !!
« on: 23 November 2010, 22:23 »
As most of the regulars no i hang about this section quite a bit.. I have now got used to using all the products i have but now i wana go a step further..
My car has some quite light scratches and swirls from 8 years of previous bad washing !! I want to get myself a DA polisher and i have asked about these before so will be purchasing one soon from Waxamomo but what i really want to know is what starter products shall i buy to use with the polisher..
I want a slightly aggressive compound to remove some deepish scuffs i have.. damage just to clearcot not at paint yet..
I want a fine polish to remove minor scratches and swirl marks..
Is there anything else i need ??
I have looked online and fancy the 3 set of 3m products and you get quite a lot for £100 is there anything else you guys recommend ??
Cheers in advance
Dan
Offline Dan J
Re: Right guys another bad question for yas :)
« Reply #1 on: 23 November 2010, 22:38 »
for vag paint menzerna polishes will give you very good results, 3m polishes are excellent but if you are using them on just your own car then the big bottles will go out of date before you have chance to use them so consider that when buying 3m.
or have a look at the wolf polishes chris(waxamomo) has just started stocking, also get yourself some ipa for wiping down after the polishing stage then use a good machine glaze to deepen the gloss and depth of the finish.
get good quality pads aswell as cheap ones will fall apart very quickly and wont give you a nice finish either.
Dan
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 23 November 2010, 22:41 »
Right dan im with you for most but what is IPA ??
menzerna stuff looks good what ones you recommend mate ??
Yer i will be in touch with Chris for his opinion soon..
Offline Dan J
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 23 November 2010, 22:51 »
do they go out of date Dan ??
Will the small ones be more than enough for me to do a few cars ??
and is there pads and masking tape you recommend ??
cheers mate
Offline Dan J
« Reply #5 on: 23 November 2010, 23:06 »
the small ones are fine and will last you ages, you only need 3/4 pea size blobs per working area and pre mist your pad with water or qd before applying polish to the pad.
pads:
http://www.i4detailing.co.uk/acatalog/Menzerna_135mm_Pads.html  scroll down for the various grades, these are perfect for DA's(not too big)
tape:
http://www.i4detailing.co.uk/acatalog/3M_Automotive_Masking_Tape_1.html   scroll down for the blue tape
« Last Edit: 23 November 2010, 23:08 by Purple Haze »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 23 November 2010, 23:10 »
Cheers for that Dan.. I am thinking of the das pro polisher would you recommend this or another ??
Offline Dan J
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #8 on: 23 November 2010, 23:24 »
thats a very good price.. should i buy the other menzerna product separately ??
Offline Dan J
« Reply #9 on: 23 November 2010, 23:33 »
you could do or email matt before you order and he'll sort something out for you im sure.
