Author Topic: need some help/info guys!!!  (Read 2916 times)
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
« on: 23 November 2010, 21:17 »
im back 2 a golf again after my jap phase... lol... cant beat the german built cars... right ive just bought a mk4 1.8 20v gti non-turbo AGN, its been stood for 2-3 months prior to me buying it now the problem im having is when driving at low revs it sort of feels like the revs are fluctuating and the car will bouce/ chug if you know what i mean!!! and it drinks fuel big time... has anone got any ideas as to what it may or is wrong? cheers guys
...Burn Rubber...Not Your Clutch...
Offline tech1889
  • Mk2 GTI FTW !!
Re: need some help/info guys!!!
« Reply #1 on: 23 November 2010, 22:14 »
need to get it scanned for faults mate might be MAF sensor..
Offline hainesz
« Reply #2 on: 23 November 2010, 22:56 »
niceone buddy... do you mean pluged into vag-com? or diagnostics? or either?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 23 November 2010, 22:57 »
both the same buddy.. yer get a friend or a garage to get it coded for fault codes.. come back list them here and we will help with what to replace  :smiley:
Offline hainesz
« Reply #4 on: 23 November 2010, 23:36 »
niceone... cheers buddy
Offline hainesz
« Reply #5 on: 26 November 2010, 22:45 »
heres what i got on vag-com
VCDS-Lite Version: Release 1.1
Friday, 26 November 2010, 22:39:53.
Control Module Part Number: 06A 906 018 CL
  Component and/or Version: 1,8l R4/5V  MOTR HS V02
           Software Coding: 04000
            Work Shop Code: WSC 00028
                      VCID: 6EAF4DBB3999
1 Fault Found:
16518 -  Oxygen (Lambda) Sensor B1 S1: No Activity
        P0134 - 35-00 -   -
so does this mean new lambda sensor, would this cause the trouble i described earlier?
« Reply #6 on: 26 November 2010, 23:38 »
If it has been sat around it might be the old petrol, put some fresh in and some injector cleaner and give it a good run.
Offline hainesz
« Reply #7 on: 27 November 2010, 02:31 »
it had no petrol in it when i got it and ive done a whole tank in it since... and ive drove it like i stole it since i got it... lol... why would it be telling me the lambda's not working?
Offline hainesz
« Reply #8 on: 27 November 2010, 17:37 »
can anyone shed some light on the vag-com code?
Offline vwblackmk4gti
« Reply #9 on: 27 November 2010, 19:28 »
if you want to be extra certain that its the lambda, check the resistance with a multimeter. and you should have your answer, you can get the ohms readings from auto data or tolerance, i can post them if needed
