Author Topic: Idle Hunting  (Read 1830 times)
Offline AudiS2
Idle Hunting
« on: 09 February 2005, 15:16 »
Hi, just to let you know I'm the older brother of GreenDA, ive prettry much fixed everything on the car with the idle problems, was mostly air and vacume leaks, though now it seems to be running smooth, just hunting for the idle the whole time, when i pump the break the revs stay at 1600 ish and doesnt seem to hunt too much, am i right in thinking this could be a vacum leak from the brake servo (brake bomb).
Cheers any help appreciated.
Mike
Offline Horney
Re: Idle Hunting
« Reply #1 on: 09 February 2005, 15:20 »
Yeah I'm afraid that does sound like a brake servo. If youhave checked and sealed every other vacume leaks then it can't really be anything else anyway.
I'd double check everything though just in case, as shelling out for a new servo and not needing it would be rather upsetting!
Offline AudiS2
Re: Idle Hunting
« Reply #2 on: 09 February 2005, 15:38 »
Bugger, well i will double check all the lines how much is a brake servo? just so i can plan the damage.  :cry:
Offline Horney
Re: Idle Hunting
« Reply #3 on: 09 February 2005, 15:50 »
Not entirely sure, you could get a second hand one (THere are a few people breaking MKII's in the "Parts for sale" forum) or you could look up the cost of a new or exchange one on sites like www.gsfcarparts.com
Offline Gambit
Re: Idle Hunting
« Reply #4 on: 10 February 2005, 17:21 »
check EuroCarParts they aint that dear from what i remember
i wouldnt buy 2nd hand when it comes to brake servo's & master cylinders!!
Offline AudiS2
Re: Idle Hunting
« Reply #5 on: 10 February 2005, 18:11 »
All sorted, was a slight vacume leak, now the mixture is all set shes driving like a dream!!!
YEA  :grin:
Thanks for the help no doubt i will be back here in the future!
Mike
Offline Lee Watson
Re: Idle Hunting
« Reply #6 on: 05 April 2005, 14:25 »
Where did you find the leak because I have the same problem?
 :undecided: :undecided: :undecided:
