Author Topic: Mk3 Gti 8V tuning  (Read 6040 times)
Offline harlemex
Re: Mk3 Gti 8V tuning
« Reply #10 on: 01 December 2010, 14:57 »
Khare also said an 8v on decent shocks will beat a 16v on the track.  :drool:
Offline VR6_Wherry
« Reply #11 on: 01 December 2010, 15:12 »
No, he actually said "a good handling 8v with decent brakes will outperform a standard 16v around the track." Yes it is Andres but that doesn't make it a fact!  :grin:
Good handling and Mk3 don't really go well together.  :grin:
It would cost no more or less to upgrade the suspension and brakes on the 16v then it would to the 8v. Cost + performance is greater with the 16v  :wink:
Offline harlemex
« Reply #12 on: 01 December 2010, 16:16 »
amounts to the same doesnt it?
Offline Len
« Reply #13 on: 01 December 2010, 16:23 »
Khare says a lot of things! Mostly rubbish!
Like his 8v would be more powerful than my 16v! Until JKM in Porstmouth! Since then he kept his mouth shut!
www.sas.org.uk
www.the-ace.org.uk
Offline harlemex
« Reply #14 on: 01 December 2010, 16:35 »
what happened Len?
Offline VR6_Wherry
« Reply #15 on: 01 December 2010, 16:53 »
No, because that would mean the handling of the 8v would be modified. For the exact same cost you could do that to a 16v which would make it out perform a modified 8v.
Offline harlemex
« Reply #16 on: 01 December 2010, 17:13 »
why are you argueing with me? I just pointed out what Khare said. And that was pointed out earlier. You referred to khare having an 16valver over an 8v, I referred to him saying about an an 8v with good handling and decent brakes(ie not standard) would beat a standard 16v round the track. And thats presicesly what he said, So you aint making sense.  :kiss:
VW BUSH
« Reply #17 on: 01 December 2010, 18:11 »
Port TB,Smooth air box + filter, Cat back, PB cam, Swap gearbox for one with lower FD..............
If you want handling and fast try an M3  :wink:
Offline Khare
  • The bear that khares
« Reply #18 on: 02 December 2010, 13:05 »
I was on about TORQUE Len. And remember the result? Oh yeah, I beat you and your exhaust system, remap and filter combo, with my standard, unserviced 8v at the time  :grin:  :tongue:
Again my superiority was demonstrated at Rtech's RR day, 138ft-lb  :wink:
What I mean is a standard 8v will loose against a standard 16v, but an 8v with chassis modifications (suspension, ARBs, brakes) will outhandle a 16v, and over a lap make up time over the 16v, unless that lap is of the indianapolis track....
Yes for the same cost you could do a 16v, that that would be a modified 8v, but the OP hasn't got a 16v so he wouldn't be able to afford a 16v AND chassis upgrades.
Of course a lot depends on who's driving and weather conditions.
Offline Len
« Reply #19 on: 02 December 2010, 13:10 »
I thought I beat you at Portsmouth!
www.sas.org.uk
www.the-ace.org.uk
