This I find weird, but been told it a common problem. However never come across it before
other day I noticed my drivers side rear wheel was sitting alot lower than the passenger side one. I thought ah broken spring. Got it on the ramp checked and no, ok must be a failed shock so changed the rears which are less than a year old. Lowered it back down and stiill the same. so back up on the ramp check the bushes all seems fine there. Stand back and look at the car and notice that the drivers side mudflap is at an angle to the wheel. Gret out a spirit level and check the axle just behind the stub and level on passenger side but out on the driver's side so got a bent axle. checked the inner of the drivers side alloy so buckles and I know I havnt hit or gone over anything that would hit the underneath of the car. What can of caused this or is it just a flaw?
car is a 1996 n plate cabriolet with 160 ish on the clock.
