Author Topic: what next ?  (Read 2160 times)
Offline theclash
what next ?
« on: 23 November 2010, 20:02 »
bloody coolant warning light....again..... :sad: so far ive replaced header tank, header cap, black 2pin temp sensor, flushed and changed the coolant, read every topic available and still havnt cured it. as soon as the engine gets up to tempreature the light starts flashing the car isnt overheating and the coolant level is good fan kicks in as it should. im stumped so any more sugestions welcome
Offline apie2004
Re: what next ?
« Reply #1 on: 23 November 2010, 20:59 »
Call it a lying cun!t
Offline xkaty_h
Re: what next ?
« Reply #2 on: 23 November 2010, 21:08 »
Stick a little piece of blue tack over it!
Checked the thermostat?
Mine wasn't opening fully and when it was replaced my coolant light stopped coming on.
Offline theclash
Re: what next ?
« Reply #3 on: 24 November 2010, 00:14 »
[/quote]
yep had a new genuine vw thermostat
Re: what next ?
« Reply #4 on: 24 November 2010, 09:28 »
bridge the pins on the level sensor plug. if it still does it, the wiring to the level sensor or the dash itself is at fault. was the black sensor gen vag?
Offline battman
Re: what next ?
« Reply #5 on: 24 November 2010, 11:21 »
hi there,
i had this problem with my oil light and buzzer.
i replaced the oil sender sensor, then got a mechanic mate to check it, he said my brand new sensor was faulty, be wary of new parts, it doesnt guarantee they are working properly!!!
just a heads up! :smiley:
Offline theclash
Re: what next ?
« Reply #6 on: 24 November 2010, 20:28 »
hi there,
think you may well be right carnt think off anything else it could be so me thinks i will try and swap the sender for another and see what happens.
