Author Topic: Radiator  (Read 999 times)
Offline DTGTI
Radiator
« on: 23 November 2010, 19:39 »
Does anyone know if the radiator from a VR6 will fit the GTI 16V? ( know VR6 is a double fan and gti's a single)
Offline Khare
  • The bear that khares
Re: Radiator
« Reply #1 on: 23 November 2010, 20:03 »
The VR6 will have the outlets a bit lower down, and the bolt holes won't line up, you'll have to hack away a bit at the plastic cowling around the radiator. However the slam panel will hold it in place, so no need for bolts. I've got a VR6 rad cooling my 16v.
Offline jonnypolish
  • t2871r needed :)
Re: Radiator
« Reply #2 on: 23 November 2010, 20:05 »
Been thinking of a VR rad on mine, So yours is just supported by the slam panel khare?
No other bodging needed?
So i'm guessing if you wanted the whole shabang you could just slap a VR front end on?
 MK2 VR y0!
Offline Khare
Re: Radiator
« Reply #3 on: 23 November 2010, 21:23 »
Yup, the hoses support it enough and the slam panel stops it from going out the front.
Re: Radiator
« Reply #4 on: 23 November 2010, 21:41 »
Why would you want to fit a VR rad.  :undecided:
Offline Khare
Re: Radiator
« Reply #5 on: 24 November 2010, 00:03 »
More cores? Better cooling? Maybe found one cheap?
Offline jonnypolish
  • t2871r needed :)
Re: Radiator
« Reply #6 on: 24 November 2010, 11:35 »
Pretty much :D
And it  looks better with the dual fans!
 MK2 VR y0!
