Author Topic: help please  (Read 698 times)
Offline flash-derby
help please
« on: 23 November 2010, 18:57 »
my car has just started to make a horrrible screechin noise when turning the steering, normally when its cold or you chuck it into a courner so turnin the steerin fast
(hope that made sense  :laugh:)
so been told a fubared pas pump but the been told it will be the pas belt, now i recently did the the cam belt/ alt belt  but didn't get the pas belt.
so has anyone had this and what was the outcome?
cheers
if its got pistons or tits, either way its gonna be expensive
Offline robiwill
Re: help please
« Reply #1 on: 23 November 2010, 20:20 »
try adjusting the powersteering belt sounds like it is a little loose there is an adjuster
Offline javalin
Re: help please
« Reply #2 on: 24 November 2010, 12:12 »
change the PAS belt at the same time.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Len
Re: help please
« Reply #3 on: 24 November 2010, 12:16 »
Adjusting it does work.......
for a very short time!
So replace the belt! They are only 8 quid from ECP, just make sure you get the right size, its bigger for a car with aircon.
www.sas.org.uk
www.the-ace.org.uk
