Author Topic: hub-based long shot  (Read 1554 times)
Offline lewis1641
  • stuck in the 90's
hub-based long shot
« on: 22 November 2010, 22:51 »
has anyone fitted vauxhall hubs to  a mk2? if so what parts did you use?
Offline mk2bal
Re: hub-based long shot
« Reply #1 on: 22 November 2010, 23:00 »
Yeah I have- In the end I used a can of 'what the f*ck are you on about mate'
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 22 November 2010, 23:10 »
lmao at above..
Offline lewis1641
  • stuck in the 90's
« Reply #3 on: 22 November 2010, 23:34 »
 :rolleyes:
hubs are the bits of metal between the wheel bearings and the wheels. i am trying to fit a particular set of wheels to my car and a hub conversion is seeming to be a sensible option. just wondering if anyone has done this before i go spending money on trial and error bits.
« Reply #4 on: 23 November 2010, 00:05 »
Vauxhall is 4x100 or 5x112 would adaptors not be easier.
Offline Cory
« Reply #5 on: 23 November 2010, 02:50 »
i know someone who has mk3 astra wheels on a mk1,  are mk1/mk2 hubs the same?
Offline lewis1641
  • stuck in the 90's
« Reply #6 on: 23 November 2010, 09:01 »
Sorry guys, i'm thinking 5 stud vauxhall 5x110
« Reply #7 on: 23 November 2010, 09:10 »
Adaptors, redrill your hubs or wheels then.
Offline lewis1641
  • stuck in the 90's
« Reply #8 on: 23 November 2010, 12:35 »
problem with all of those is thatone bolt hole will be very very close to another. this is why the adapters area, hard to find and b, expensive when you do find them as the problem has to be engineered out.
i am not keen on redrilling hubs or wheels forthe same reason
