Author Topic: rear windows  (Read 1258 times)
Offline darcy
rear windows
« on: 21 November 2010, 14:48 »
hi all,just wanting some advice on sorting out my rear electric windows.
well never used and now i wanted to they wont go down
the fuse is ok and you can here a click sound when pressing the botton for them but they dont move at all.
anyone else had this problem thanks D
Christo77
Re: rear windows
« Reply #1 on: 21 November 2010, 14:59 »
Elec windows are a common problem on these, ie they fail at some point..I've had to fix all four of mine.
A mistake i think with these things is not' to use them! then one day you do and presto, no worky..so, they might simply be stuck if your just hearing a click coming from the actual door..
Offline darcy
Re: rear windows
« Reply #2 on: 21 November 2010, 17:04 »
yh maybe so as the sound is from the unit itself. Was going to take the door card off and clean around the window and runner ect. But just not had the time today. Only just sorted one at the front out. So will see when i end up doing it.
Offline *Jonnyg*
Re: rear windows
« Reply #3 on: 21 November 2010, 17:48 »
My drivers 1 use to click, and now it doesnt click at all :(
Think i need a new motor!
** Tuned diesels - kinda like a guy with a huge cock and premature ejaculation. **
Christo77
Re: rear windows
« Reply #4 on: 21 November 2010, 18:14 »
Don't give up on it..the motors do fail but not often, usually it's the window regulator mechanism..or wiring/through the rubber boot door-pillar..or the actual switch.
Offline ant_gti
  • mk3 20v turbo
Re: rear windows
« Reply #5 on: 21 November 2010, 20:24 »
+1 :cool: defo check wiring in the rubber boot
Offline whereufromnosecity
Re: rear windows
« Reply #6 on: 21 November 2010, 22:26 »
My drivers rear is the same, but since i have the lock on it to stop the kids for hanging out and throwing stuff at predestians it's quite low on my list of things to do
One day we will be going on holiday in Miley the camper
