Author Topic: Catch can inlet/outlet 19mm, essential?  (Read 4483 times)
Offline golf-sib
  • Турботазик
Re: Catch can inlet/outlet 19mm, essential?
« Reply #10 on: 22 November 2010, 22:21 »
Use to have one of them, the only problem I had was the see-through level tube warped and started leaking. But with a jubilee on a 19mm ID tubing you can make it air tight onto a 15mm ID head. Will need a extra tighten every so often but then it will be magical and be sealed tight. I achieved this on couplin silicon which is very thick and stiff, so if I can compress that to a 15mm diameter i'm sure you can
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #11 on: 22 November 2010, 22:31 »
reducers are probably best and easiest route lol
Offline Waffs1984
  • Spacers are for chumps...
« Reply #12 on: 23 November 2010, 09:35 »
Yeah hunt on ebay there's load of silicone suppliers, quick delivery too!  :smiley:
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline rio_gti
Offline 2001gti4
« Reply #14 on: 09 December 2010, 16:07 »
Answer on your other thread....
My Golf is dead but at least I have this....
Offline Dave_IOW
« Reply #15 on: 09 December 2010, 20:25 »
my turn to fit a tank too!!!
found these am i right in thinking that its the same tank as the first post??? and will the hoses be correct too??
cheers peeps  :smiley:
http://cgi.ebay.co.uk/UNIVERSAL-BLACK-ALLOY-OIL-CATCH-TANK-10MM-15MM-INLETS_W0QQitemZ360325031454QQcategoryZ72205QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DDLSL%252BSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D8%26pmod%3D350369329147%252B350369329147%26po%3D%26ps%3D63%26clkid%3D5506935966847411851
http://cgi.ebay.co.uk/19mm-Oil-Catch-Can-Kit-Special-Deal_W0QQitemZ230495679573QQcmdZViewItem?rvr_id=181428014335&rvr_id=181428014335&cguid=dc9ab6be12a0a0aad254e7f4fe4db87f
unless anyone can reccomend somethin on the same price range......
Can outlet = 10mm or 15mm
Hose inside diameter = 19mm so you would need silicone reducers.
I got myself a Sachi one in the end with 19mm inlet/outlets.. cheers adam :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
