Author Topic: idle-ing issues, Here Goes again;  (Read 2258 times)
Offline casey-carl
« on: 20 November 2010, 15:54 »
Hi,
First I would like to thank a couple of people, dom069 your irony and useful tips have kept me going and horney, you input has been of help as well.
First I will explain the car 1992 Golf Mk3 GTI-V8! 1.8
The issue:
Rev's more between 400-800-1100-2000-400-stall
The things done so far:
1. TB taken off and cleaned
2. ISV taken off and then replaced, then new one on
3. Mass air flow changed
4. All air hoses removed and cleaned
5. Dizzy done
6. plugs done-leads done
7. Lambda sensor removed-and replaced
8. all leads checked and wd40 sprayed to check for air leaks.
if the exhust is incorrtly fitted would this casuse an idle problem, I also  removed the dip stick while it was running and this seemed to enhance the issue.
any ideas? thank you  :sick: :sick: :sick:
i'm now thinking it could be the timing belt out and also the TB needs realineing
« Last Edit: 20 November 2010, 15:57 by casey-carl »
Christo77
Re: idle-ing issues, Here Goes again;
« Reply #1 on: 20 November 2010, 16:09 »
A GTi V8 ? that's a serious mod!  or maybe you mean an 8V   :shocked:
Not wanting to jump in on the other guys help..but your getting there for sure,
Don't forget those pesky relays..not sure of the numbers on a 1.8.. !
Water temp sensor..?  and by all means check the timing and TB alignment..
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 20 November 2010, 16:10 »
Id check the breather pipes (very common for splitting)  seeing as you mention the idle is affected whilst removing the dipstick.
Offline dom
  • Back in a Mk4
« Reply #3 on: 20 November 2010, 16:23 »
Hi,
No problem, I aim to please :afro:
In truth i'm supposed to be writing a critical reflection on how ICT contributes to the Personalisation Agenda, so i'm taking any opportunity to distract myself from it, I just happen to be in a bit of a sarcastic mood today  :grin:
Offline justalex81
« Reply #4 on: 20 November 2010, 16:54 »
since when has a mk3 gti only been a 1.8?
Offline dom
  • Back in a Mk4
« Reply #5 on: 20 November 2010, 16:57 »
 :laugh: Didn't notice that!
Christo77
« Reply #6 on: 20 November 2010, 17:05 »
I did..and it's a V8 ! :wink:  but..you never know with these things,
Offline casey-carl
« Reply #7 on: 20 November 2010, 17:52 »
Ok, typo by me? 8v not v8.
have changed the 30 relay the ECU one
have changed the 167 fuel relay
done them as well....
how do you check the timing any pictures or links to follow:
 :evil:
Christo77
« Reply #8 on: 20 November 2010, 18:00 »
No worries ole chap, we all do typos..  :wink:
Not exactly sure which model you have.. 1.8 !?  anyways, a manual will help..show you how to line up the timing marks on the flywheels for TDC, then line up dizzy rotor arm..again according to your model,
If it's a 1.8 Mk3.. you sure it's not a CL/GL or a Driver spec'd up body wise to a GTI ?
« Last Edit: 20 November 2010, 18:14 by Christo77 »
Offline casey-carl
« Reply #9 on: 20 November 2010, 18:37 »
hi,
the car is a 1992 - vw golf gti 1984cc engine number: 2e157292 is that any help !!!!
