Author Topic: Stuck starter motor bolt  (Read 3000 times)
Offline jmsheahan
« on: 20 November 2010, 12:49 »
Why is it the 'simple' jobs always give the most arse ache?  :rolleyes:
I tried to clean up the starter motor connections today to see if solved the hot start problem. The nut that holds the electrical leads to the starter motor is rather rusty. I tried to undo it but now the threaded shaft it sits on just goes round with the nut. I've soaked the nut in penetrating fluid but any ideas how to get it off? Not a lot of access there.
It undid a fair few turns and then just got stuck. So now the leads are loose and a connection can't be made.
« Last Edit: 20 November 2010, 13:38 by jmsheahan »
Offline jmsheahan
Re: Stuck starter motor bolt
« Reply #1 on: 20 November 2010, 13:38 »
Offline weazgti
« Reply #2 on: 20 November 2010, 14:23 »
cant you sort of lever a screwdriver or something behind it and try and wind the whole thing out?
Offline jmsheahan
« Reply #3 on: 20 November 2010, 14:26 »
Will the shaft just wind out completely then? Doesn't seem to be going anywhere.
Offline beechymonza
  • mad beech
« Reply #4 on: 20 November 2010, 15:10 »
Or try an cut the nut of somehow, I know its tight, But a hacksaw blade an just persevere with it,
And then you could pack the bolt up with some washers after and put new nut on 1st bit of the thread,,
No guts No glory,
Offline jmsheahan
« Reply #5 on: 20 November 2010, 15:16 »
Yeah I think I'm going to have to cut the damn thing off.
If I cut the nut off I should have 1-2 threads to nip a new nut up on the end. Lost the light now, will have to do it tomorrow. I hate cars  :angry:
Offline beechymonza
  • mad beech
« Reply #6 on: 20 November 2010, 15:30 »
Yeah that should be enuff thread 2 keep it tight,
It always happens on a cold dark day 2 doesnt it, :cry:
I started 2 tighten my Power steerin belt up under car last week,
Took wheel off undid nuts an then slammed me finger in car door,
Believe me i was in tears puttin it all back 2gether after,,
No guts No glory,
Offline clipperjay
« Reply #7 on: 20 November 2010, 17:03 »
Can you get mole grips on the thread then use a spanner? Other wise I would cut the nut off if it doesn't budge?
Offline jmsheahan
« Reply #8 on: 20 November 2010, 17:16 »
Isn't that the truth mate!
I'm hoping so. Pliers did nothing and don't have any molegrips but hoping to blag some tomorrow. As the shaft turns to I'm concerned I've broken something inside the solenoid? It still starts fine though if I bridge the gap, just makes a few sparks  :laugh:
I'll get the grinder out tomorrow to cut it if not as you say.
Offline clipperjay
« Reply #9 on: 20 November 2010, 17:19 »
If it starts you have not fubared it mate its just a long metal connector worst case stick a grub screw type of nut to hold the circular clips in place  :wink:
