Author Topic: can i call anyone for help plz vr6 clutch 1.8t!!!  (Read 1880 times)
Offline gtti_234
« on: 20 November 2010, 09:57 »
Hi guys im having a vr6 clutch and g60 flywheel put on my agu 1.8t on tuseday there is a few things im unsure about could i please give someone a call who has had the conversion done. Ie do i need to worry about crank sencers or bearings. Or will it all fit straight on? Its a costly mistake if i get it wrong cheers guys.
spax coil overs, 18ins rs8 alloys,007 forge dv,n75j,piper cross induction, r-tech stage 2 remap, custom chromes decat exhaust + 3" down pipe, forge actuator g60 flywheel vr6 clutch, forge tip, deleted pvc catch can install,
Offline gtti_234
Re: can i call anyone for help plz vr6 clutch 1.8t!!!
« Reply #2 on: 20 November 2010, 10:15 »
Thankyou mate it was helpful just want to no if i can re-use the thrust bearing i already have on my agu. Cheers
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #3 on: 20 November 2010, 10:19 »
if youve bought a clutch kit then thrust bearing should come part of the kit, if not replace it.
Offline gtti_234
« Reply #4 on: 20 November 2010, 10:28 »
Thanks for the reply no i didnt get one with it. i will try and Buy a new one but if i cant find one in time can i reuse the one i have already on my agu cheers
Offline vwprime
« Reply #5 on: 20 November 2010, 10:31 »
Exactly that mate. Should be in the kit if not CHANGE IT. You dont want to take the box of agane to change it, if you dont do it know. As for crank sensors you will be ok. Fallow the links which other people have put up on here and you will be fine.
TRANSFORM, & ROLL OUT!
Offline gtti_234
« Reply #6 on: 20 November 2010, 10:43 »
Sorry im just getting paranoid just dont want it to go wrong so im guessing the thrust bearing for the 1.8t is the same as the vr6 and i can pick these up at any car parts dealer.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 20 November 2010, 11:30 »
yes mate thrust bearing is the same. Not sure on who would stock it, would be worth ringing around  :smiley:
Offline richw911
« Reply #8 on: 20 November 2010, 17:13 »
Why guess? All the info is in the link Wayne posted  :smiley:
Offline gtti_234
« Reply #9 on: 24 November 2010, 19:43 »
Just want to say a massive thankyou to all you guys who have helped with me pestering them for advice on parts and fitting the clutch and flywheel are all in and seem to be fine clutch is as light as a feather. for labour and parts all in i payed £240.00 thats including vat! !!!
