Author Topic: DV pressure release...+ other bits  (Read 748 times)
Offline Big Tone
« on: 19 November 2010, 17:06 »
Done loads on the beast today, thermostat, coolant change, replaced all cable ties with mini hose clips, rear caliper investigation, bit of work on the rear washer, pressure test and full wash.
When I did the pressure test, my DV (Forge 007P), was allowing air to re-circ back into the TIP at approx 1 Bar, this I thought was a bit low, so I have shimmed the spring (Yellow forge) to make the DV "lift" at roughly 1.2 Bar, see if she holds a bit more boost.
Will this F**K anything up? Haven't driven her yet.
Also, has anyone replaced the offside rear handbrake cable before? that needs doing.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline tech1889
  • Mk2 GTI FTW !!
Re: DV pressure release...+ other bits
« Reply #1 on: 19 November 2010, 17:15 »
Shiming the spring is fine as lots of people do it to fine tune as the springs are mass made they can vary in opening times. Can't see handbrake cable being that tricky.
Offline Big Tone
« Reply #2 on: 19 November 2010, 17:21 »
Nicely, can you get the cables seperate or do they come as a set?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 19 November 2010, 17:25 »
I honestly don't no mate sorry.
Offline Big Tone
« Reply #4 on: 19 November 2010, 17:29 »
No worries man, I will have a bit of a hunt
