Author Topic: am i running rich?  (Read 1317 times)
Offline bluquarta
am i running rich?
« on: 19 November 2010, 12:13 »
Chaps
Going from searches on here I think my 98 8v is running rich.
ok so these are the symptoms:-
- intermittent poor starting eg. struggles to idle, ok if given some revs for 10 secs or so. Oil light comes on briefly sometimes when it does this
- notice petrol smell more when this happens. Soon goes after car warms up
- renewed spark plugs recently, checked them last weekend and seem to have 'blacker'deposits than would be expected for only a month old!
This seems to have started occurring since I replaced plugs, HT leads, dizzy cap and rotor arm. If I had put dizzy cap slightly out of line would this account for it maybe?
It idles less roughly than before I did the service. I think it is idleing at a higher rpm than before now, but I have also recently switched to Super unleaded and the idle seemed to have got slightly higher since I first put that in the tank.
cheers
Re: am i running rich?
« Reply #1 on: 19 November 2010, 12:16 »
The mixture is controlled by the ecu so if it is running rich you might find the temp sender is playing up and leaving it on the cold start map longer.
« Reply #2 on: 19 November 2010, 13:07 »
disconnect plug to lambda probe, if its better chances are you need a new one :)
also clean out the throttle body till its shiny to rule this out, and look it over carefully for vacuum leaks asnd splits in the inlet piping
Offline bluquarta
« Reply #3 on: 19 November 2010, 15:24 »
cleaned throttle body recently. did a visual inspection of the pipes, seem ok. where is the plug for the lamba probe?
« Reply #4 on: 19 November 2010, 15:35 »
its the 4 pin one clipped to the rear engine mount bracket :)
Offline bluquarta
« Reply #5 on: 21 November 2010, 17:21 »
hmmm... had a look for the lambda plug today, couldn't find it! Sorry, being dim, but what is it near? Not sure where the rear engine mount bracket was. Anyone got a pic?
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 21 November 2010, 18:48 »
lambda sensor connection is behing the engine on your left hand side if looking at your engine
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #7 on: 22 November 2010, 11:35 »
look right down back of engine, the rear mount is what holds rear of engine to the subframe, cant miss it. its near the chassis leg and steering rack. should be a 4 pin plug sat down there somewhere
