Author Topic: vr6 clutch g60 flywheel!!!!!!  (Read 753 times)
Offline gtti_234
« on: 18 November 2010, 19:53 »
hi guys i have just bought a vr6 clutch and g60 flywheel second hand i have been told that there is plenty of life left in the clutch and need it fitted asap as mine is on its way out. the unit ie clutch and flywheel are all bolted together and i need a socket of some sort to take the clutch pressure plate bolts off of the flywheel any ideas of what kind of socket? and also where can i buy a new 12 bolt set cheers.
spax coil overs, 18ins rs8 alloys,007 forge dv,n75j,piper cross induction, r-tech stage 2 remap, custom chromes decat exhaust + 3" down pipe, forge actuator g60 flywheel vr6 clutch, forge tip, deleted pvc catch can install,
Offline houston
Re: vr6 clutch g60 flywheel!!!!!!
« Reply #1 on: 18 November 2010, 20:51 »
get the bolts from vw
are they not torx bolts?
dellenty69
« Reply #2 on: 19 November 2010, 00:11 »
Offline Dave_IOW
« Reply #3 on: 19 November 2010, 18:29 »
Sure the bolts i got to bolt my pressure plate on were allen key bolts?
Were genuine ones..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
